Wire Route
  • tlh0824
  • tlh0824's Avatar Topic Author
Wire Route was created by tlh0824
1976 DT 400
Hello, I am trying to figure out the proper location of the wire looms from the headlight. Do any of these wires go through the frame underneath the neck? or do they both go through the bracket, under the tank? if anyone has a picture that would be great. I know there is a routing diagram, but its a bit confusing.
Thank you
Tom
07 Nov 2019 09:09 #1
Replied by Gr8uncleal on topic Wire Route
I don't have a DT400 and so can't post pictures. However, I do have a DT360 and used the cable Yamaha cable routing diagram for that.
I agree that they do need to be looked at carefully. Just in case you weren't aware, where there is a broken line, this is showing the route of an item, but it means that it is going behind whatever it is printed over. So on your attachment, it means that the rubber cover and the wires therein sit on the left side of the front of the frame.
07 Nov 2019 10:08 #2
Replied by Lizeec on topic Wire Route
Those wires in your picture sit inside the frame cavity where the (2) frame down tubes merge, the picture is showing the slot where the fuel tank rubber sits in and the holder for the throttle cable junction.
Last edit: 07 Nov 2019 11:16 by Lizeec.
07 Nov 2019 11:15 #3
  • tlh0824
Replied by tlh0824 on topic Wire Route
I have three sets of wire, the key wire, the gray switch wire, and the main wire loom. All three wire sets are on the left side (shift side). Currently, the key wires and the switch wires go through the frame and the main loom goes around. It feels a little goofy and the previous owner half-assed a few things so I wouldn't be surprised if this was wrong. Does anyone know the correct path? I attached some pictures.
Thanks, Tom
I am having trouble uploading photos
Last edit: 08 Nov 2019 07:15 by tlh0824.
07 Nov 2019 14:35 #4
  • tlh0824
photos
Last edit: 08 Nov 2019 07:18 by tlh0824.
08 Nov 2019 07:16 #5
