Cheap light switch on ebay
- tlh0824
Cheap light switch on ebay was created by tlh0824
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=322835256370&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
- Lizeec
Replied by Lizeec on topic Cheap light switch on ebay
I recently bought one as my headlight switch was broken, I emailed DEET and was quoted a rough estimate of $150 to repair & restore my original or he had N.O.S. ones for $125.00 I ended up buying one off amazon for $25.00 definitely not O.E.M. quality but worked just fine for one of my riders. I did add some shrink tubing protection where the wires terminate same as the O.E.M.
Replied by Gr8uncleal on topic Cheap light switch on ebay
Always try and fix the original first.
Take it all apart and give it as good a clean as you can and look for any piece of rogue material that might be causing your horn and lights to randomly come on.
22 Oct 2019 10:56
Replied by MarkT on topic Cheap light switch on ebay
One thing about original Yamaha is that the hi-lo headlight switch never disconnects... there is actually a moment when both filaments are getting power.
This is done because as discussed (to death) the original system is designed to keep the voltage within limits by balancing the bulb load against the fixed stator output. If the switch allows even a momentary break (no load) between high and low beams the spike in voltage could contribute to blowing a bulb... if bike has a good regulator in the headlight circuit this is not a concern.
22 Oct 2019 13:09
- 2fishkev
Replied by 2fishkev on topic Cheap light switch on ebay
I don’t know if this is the place to share this info, but I successfully used a pw50 toggle switch -eBay $11- to fix my dt125a switch. Just had to swap copper contacts.
rover.ebay.com/rover/0/0/0?mpre=https%3A...2Fitm%2F311569974515
- AirborneSilva
Replied by AirborneSilva on topic Cheap light switch on ebay
WOW for $19 it might be worth a try. When I first got my bike the horn didn't work and the turn signal switch wouldn't go to the right, I did take it apart and got them working but it's not 100%, I might try one of these cheap ones since I wouldn't be out much if it wasn't too good but on the other hand be golden if it did!
22 Oct 2019 16:36
