1974 DT250A Vs DT250B
- Camp3
1974 DT250A Vs DT250B was created by Camp3
Hi all, had a great summer working on and riding my DT175C with a dented tank. I am setting up my winter project which is a DT250A with sand ingested in the motor by previous owner. My question relates to the 250A Vs 250B. Is the 250A a 1 year wonder? It has the unpainted engine case with a 450 prefix engine. I have a spare motor with a 450 prefix serial number and is painted black and is from a 1975 Model Year. Both years have a 450 engine model but don't look to be interchangeable which is a bummer, unless some of you can tell me different...Thanks
1976 DT175C
1975 DT100B Kid Trainer
1974 DT250A In Process
1992 FJ1200
1992 FJ1200
21 Oct 2019 18:15
- Steve F
Replied by Steve F on topic 1974 DT250A Vs DT250B
Pic's of the differences you speak of would help.
It is my understanding that A,B & C are mostly the same.
Did you try to fit the B engine into the A frame?
And the DT250A is as solid as they come.
1974 DT250A
1974 DT250A
1977 IT175D "Alex"
1978 IT175E
1972 DT2 "Adam"
1973 DT3
"And there ya have it"
1974 DT250A
1977 IT175D "Alex"
1978 IT175E
1972 DT2 "Adam"
1973 DT3
22 Oct 2019 14:03
Replied by MarkT on topic 1974 DT250A Vs DT250B
Curious as to what you are basing the "don't look interchangeable" question on... parts lists? Or the actual engines?
Parts lists will show a different number if the finish on the part is different (silver vs black) and sometimes for no reason at all...
I don't know much about the larger bikes but in my general experience if the model code is the same for multiple years the basic parts are the same or interchangeable.
22 Oct 2019 15:26
- Camp3
Replied by Camp3 on topic 1974 DT250A Vs DT250B
The two motors in the post are a 1974 250 and a 1975 250. The serial numbers are on opposite sides, the paint is black on the 75, the head fins are radial Vs. the square shape in the 74. The motors look different, although that doesn't mean they wont bolt up to the frames I guess, I just don't know enough about these to know if its swap-able. I don't want to get all invested in a rebuild then try to swap in the motor just to find out there is some little piece that wont work.
1975 DT250 Motor with a 450 Serial number Prefix
1974 DT250A Motor with a 450 Serial number Prefix
The below post is related to the two motors I found in pile of Yamaha motors, one is a DT250B and the other is a YZ 250A by the looks of the serial number, which one would be better for a on/off road DT250 refurb, I can't afford a NOS type restore...
yamaha-enduros.com/index.php/forums/74-7...mx250a-dt250a-motors
1976 DT175C
1992 FJ1200
1992 FJ1200
- Camp3
and here are the frames..it looks like it might be a possible swap.
DT250A
DT250B
DT250A
DT250B
1976 DT175C
1992 FJ1200
1992 FJ1200
22 Oct 2019 17:02
- Ctune80
Replied by Ctune80 on topic 1974 DT250A Vs DT250B
The DT250A, 250B and 250C for that matter are pretty much the same except for small details. '
Motor mounts are the same for all, even the DT360A and the 400B and C for that matter.
The 250A has points ignition and the straight finned head.
You can put the points ignition on the later engines and it will hook right into the 250A harness. (And probably be easier to deal with since the Hitachi CDI is "Finicky"
The 250A straight finnned head, they all interchange and I'm not aware of a performance difference. Just looks.
The Ox is slow, but the Earth is patient.....
The following user(s) Liked this Post: MarkT, sagetree33
- Camp3
Thanks! That is some good news, I have 2 spare motors for this frame, I think I can make this project work. I'll have to start a separate thread to track my progress.
1976 DT175C
1992 FJ1200
1992 FJ1200
The following user(s) Liked this Post: Ctune80
23 Oct 2019 17:53
- sagetree33
Replied by sagetree33 on topic 1974 DT250A Vs DT250B
just thought id put this out there that the crank oil seals are bigger and share the 73s seal on the 74
250A and oem are hard to find the 75and on up are a smaller seal and you can still get them at
partzilla or other sellers
18 Nov 2019 23:15
Replied by RT325 on topic 1974 DT250A Vs DT250B
I'd best not confuse the issue so take it with a pinch of salt. The YZ250A [trick worksy looking bike] has the old design cases based on a DT1. So does the worksy YZ250B first monoshock & that was also the case with YZ360B. Funny thing is--Partzilla are confusing things by showing a YZ250A 1974 with crankcases showing the next generation [so a mistake]. But the YZ360A same year shows the early cases. If you go to YZ250B or YZ360B "75 it shows the old cases for both [which is right for the trick bike] "75 also had the MX series MX250B & MX400B which had the later shape motor & cases. So--umm, not sure where i'm going now. Have had all those models at some stage when new or nearly new in the case of the YZ250B & bought an MX250B new in "75 & C model in "76. Looks like the crankcase page is the only wrong one on the 250. Must be hard for Partzilla to keep up realy with so many confusing changes in those days--& now i'm confusing things more lol.
19 Nov 2019 00:43
- Don Dieago
Replied by Don Dieago on topic 1974 DT250A Vs DT250B
If I had both motors and I wanted to know I would pull it out of frame and sit the a into frame. Dont know about you but I can have the B engine out of the frame in say 15 minutes. You say full of sand! sounds like it was sunk in a river ben there done that more than once. go ahead and pull engine and flush everything several times with clean diesel. I personally think the 74 engine looks better than the radial head black engine.
29 Nov 2019 07:34
