Dt125 won’t run
Replied by RT325 on topic Dt125 won’t run
One more guess. Have you had the starter armature off & could it have sheared off the crank key if not ightened fully. Have had a lump of stray carbon on an old AG100 Yamy jump into the baffle which on the model i'm thinking of had a baffle that was straight through with a smallish pipe but wrapped in baffle matterial. So only took a piece about the size of a 10mm ring spanner to block it, so left the baffle out for a few days to let bits escape. Video would be great with good audio if pos.
Last edit: 17 Oct 2019 18:35 by RT325.
17 Oct 2019 18:34 #11
  • Shayne00
  • Shayne00's Avatar Topic Author
Replied by Shayne00 on topic Dt125 won’t run
Right side crank seal looks a little uneven but I haven’t checked the left side yet, a couple days before I put some oil in because there was a small leak from the countershaft seal but I tapped the seal back into place and I believe it stopped leaking, I think I added too much oil and popped the seal out of place a little , it ran the same with the gas tank disconnected so I don’t think the Petcock is the issue, thanks for everyone’s help
17 Oct 2019 18:38 #12
  • Shayne00
The engine is in pieces at the moment I’m probably gonna try to seat the seals right and put it all back together I’m having some trouble finding a new seal kit for the bike so hopefully that will fix it, I’ll try to post a video once I get it together IF there’s still a problem
17 Oct 2019 18:43 #13
