74 DT250 Missing Flasher Can
  • Triumphcubguy
  • Triumphcubguy's Avatar Topic Author
74 DT250 Missing Flasher Can was created by Triumphcubguy
Just bought a 74 DT 250. It’s missing the flasher can under the tank. I see three wires that I assume are the connections. Black, brown, and brown with white tracer. I think I I need a 6V three prong can. The wiring diagrams show both 2 or 3 connections. Any help is appreciated.
30 Sep 2019 11:33 #1
Replied by Gr8uncleal on topic 74 DT250 Missing Flasher Can
Correct on all observations!
I bought a universal replacement for my 1974 DT360A, but had to pad out the rubber holder with a bit of old bicycle inner tube.
I think that MarkT (and probably others) posted on how you can use modern 2 wire units, but you'll have to use the Search facility to find the posts, sorry!
30 Sep 2019 11:44 #2
Replied by MarkT on topic 74 DT250 Missing Flasher Can
Do not buy a modern three wire flasher as they have one input, output to flashers, and output to gauge indicator.
On the OEM Yamaha the third wire is a ground and you'll have a direct short if you try to connect it to a normal modern 3 wire flasher.
A two wire will work or an exact OEM replacement that uses a ground wire as the third wire.
30 Sep 2019 13:28 #3
  • Triumphcubguy
Replied by Triumphcubguy on topic 74 DT250 Missing Flasher Can
OK, how would I connect a two wire flasher using the 3 connections That exist?
01 Oct 2019 03:21 #4
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=273949692188&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
  • Triumphcubguy
Thank Mark.
01 Oct 2019 11:48 #6
