Fuel tap 'O' ring DT400
  • NickM
  • NickM's Avatar Topic Author
Fuel tap 'O' ring DT400 was created by NickM
Anybody know where I can get an 'O' ring for my DT400 fuel tap? I need the O ring that fits around the tap lever not the filter bowl. See photo.
I've tried the usual Yambits and CMSNL. P/N 2142451300
Or, the exact size of the O ring so that I can source one.
Thanks in advance.
Last edit: 22 Sep 2019 04:43 by NickM.
22 Sep 2019 04:41 #1
Replied by nhsteve on topic Fuel tap 'O' ring DT400
Speed and Sport has 54 of them on hand. Postage probably more than the part. Hopefully someone over there might be able to help. Depends on how bad it is leaking I suppose.
store.speedandsportinc.com/
22 Sep 2019 07:07 #2
Replied by DEET on topic Fuel tap 'O' ring DT400
I have some if you can't find what you need...
The following user(s) Liked this Post: Rick C., bluntz465, swm, NickM
Last edit: 22 Sep 2019 11:01 by DEET.
22 Sep 2019 11:00 #3
  • NickM
Replied by NickM on topic Fuel tap 'O' ring DT400
Thanks for the pointer but you're right, postage is a killer. $12.80 plus postage to the UK is pushing it a bit.
23 Sep 2019 02:49 #4
  • NickM
That's very good of you DEET. I really appreciate your offer but I notice that you're in the USA and it seems odd to have to post half way across the world when I'm sure there would be thousands of these in the UK. Just a matter of correct size and material. Would you be able to measure with a vernier? ID, OD and thickness would be great.
Cheers, Nick.
23 Sep 2019 02:57 #5
  • NickM
For anyone needing one of these in the UK...
Last edit: 30 Sep 2019 02:24 by NickM.
30 Sep 2019 01:36 #6
Replied by Gr8uncleal on topic Fuel tap 'O' ring DT400
Thanks Nick, well found (assuming that they do the job!!).
Probably only cost a few pence as well?!
The following user(s) Liked this Post: NickM
30 Sep 2019 01:47 #7
  • NickM
I've had the 'o' ring in place for a week and the tap still operates fine without leaks. Cost £4 for two with post.
The points to note are the size of course but also the material and hardness (70 Shore in this case) Too soft and the material is less suited to moving or 'dynamic sealing'.
30 Sep 2019 02:23 #8
