Trouble removing bottom fork tube bolt on 1976 DT 125
- nd4965
Trouble removing bottom fork tube bolt on 1976 DT 125 was created by nd4965
Hi
I am having trouble getting the bolt out of the bottom of the fork.
I have tried it with the spring in and fork cap on but it just spins.
I have tried pushing a metal rod down to hold the dampener to no avail.
Anyone got any tricks ?
11 Sep 2019 19:55
- Bobv07662
Replied by Bobv07662 on topic Trouble removing bottom fork tube bolt on 1976 DT 125
Hit it with an impact gun a few times from a dead stop.
The following user(s) Liked this Post: nd4965
11 Sep 2019 22:01
Replied by MarkT on topic Trouble removing bottom fork tube bolt on 1976 DT 125
Yes, electric or air impact with pressure on the spring almost always works for me.
Several threads on the forum with other solutions if that doesn't work... I need to get some sleep...
11 Sep 2019 22:18
- nd4965
Replied by nd4965 on topic Trouble removing bottom fork tube bolt on 1976 DT 125
Thanks guys the impact gun did the trick.
The following user(s) Liked this Post: Rick C., MarkT, mdscott
22 Sep 2019 20:11
Great job! Thanks for the update. Getting that bolt out can sometimes be one of the most difficult and frustrating things to do.
23 Sep 2019 06:44
- Bobv07662
Glad to be a help. I've been assisted many times here myself. A great forum!
23 Sep 2019 19:25
- Dynamics
Replied by Dynamics on topic Trouble removing bottom fork tube bolt on 1976 DT 125
Hello. Can you use a impact gun to tighten up the bottom bolt as well? if so would it matter if the forks are put together when I do it? Kind regards Mitch.
11 Jun 2020 11:15
- apex
- Content Contributor
Replied by apex on topic Trouble removing bottom fork tube bolt on 1976 DT 125
Yes you can zap the bolt tight, just don't lean on the trigger. It does not to be gorilla tight, and you don't want to strip the hex.
Allrighty Then
11 Jun 2020 19:38
- Dynamics
Thanks for the response! Will give it a go later
currently rebuilding the forks for this project. dtr 125 2005 with 10130 on the clock!
- apex
Now that bike is SUPER cool!!! I wish our EPA regulations were more relaxed.
Allrighty Then
12 Jun 2020 20:04
