Headlight removal
  • smd3
  • smd3's Avatar Topic Author
Headlight removal was created by smd3
How do I remove the chrome ring from the bulb? It looks like there are wire/spring clips that need to come off, but I don’t want to pry or anything that might damage it.
22 Aug 2019 17:46 #1
Replied by Gr8uncleal on topic Headlight removal
Yes, those 3 wire "W" clips are meant to come off, then the 2 screws.
They can fly off, so 1) wear eye protectors and 2) be prepared for a search around your workshop! I reckon I've got one in the roof space of my garage somewhere!
Have fun!
The following user(s) Liked this Post: Super90, smd3
Last edit: 23 Aug 2019 00:25 by Gr8uncleal. Reason: text
23 Aug 2019 00:24 #2
  • smd3
Replied by smd3 on topic Headlight removal
Well, I got the light out of the ring. I only had one of those little springs go flying, it caught me in the neck, but I survived. (I did wear safety glasses, glad I did)
It turns out the h4 conversion is too big for the ring. Not the diameter, but the depth/angle of the backside. It might work if I hacked up the angle adjuster, but the piece is in too good of shape for that.
I ordered a standard sealed beam, and maybe I’ll be on the lookout for a ring that’s already in rough shape to MacGuyver a solution.
24 Aug 2019 17:43 #3
Replied by Rimneck on topic Headlight removal
From where and what sealed beam # did you order?
27 Aug 2019 13:49 #4
  • smd3
It was some cheapo thing on Amazon...it didn't fit. I'm not sure why I thought it would, but it was late at night and I didn't read the description well enough.
What are other people using? I'm really struggling with this one.
27 Aug 2019 16:27 #5
Is the bike a DT250B, as per the wiring diagram in the background of the first photo?
27 Aug 2019 23:48 #6
