Anyone using this 12v conversion kit from HVC Cycle?
I installed the PowerDynamo on my DT360 a few years back. Easy install, no kick back, nice system.
yamaha-enduros.com/index.php/forums/how-...t-installation#58344
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
26 Aug 2019 15:20 #21
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Replied by AirborneSilva on topic Anyone using this 12v conversion kit from HVC Cycle?
Thank you for the valuable feedback! May be the way I go since 750kr1 is the second I've heard with kickback issues on the Rex kit.
26 Aug 2019 15:36 #22
  • Mr Vegetable Trousers
  • Mr Vegetable Trousers's Avatar
Replied by Mr Vegetable Trousers on topic Anyone using this 12v conversion kit from HVC Cycle?
Here you are:
www.rexs-speedshop.com/product/dt360-dt4...th-12-volt-lighting/
I bought the system for my DT250B.
I was initially sent the wrong stator. After a quick email exchange I was asked to send it back which I did on a Tuesday. The correct stator was with me on Friday.
The bike now starts and runs perfectly. I also bought a 12v gel battery that fits the existing battery space perfectly.
The only slight issue I had was to modify the connector to the loom so it sent current to the white wire to charge the battery. DT models wiring looms have some subtle differences. That was a 5 minute job with wiring crimper.
The following user(s) Liked this Post: 750kr1, AirborneSilva
27 Aug 2019 01:11 #23
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Thank you for the reply. I wonder what's going on with some people having the kickback issue and others, like you, not. Could it be that those whom have kickback issues are modified with bored out cylinders or something like that?
27 Aug 2019 03:15 #24
No, it's the timing. Glad Rex's fixed one!
Here's some older threads.... many have had timing issues, to be fair there have been several versions of the system. And some reports of a true "plug and play" system.
yamaha-enduros.com/index.php/forums/perf...my-monoshock?start=0
yamaha-enduros.com/index.php/forum/perfo...electronic-ignitions
yamaha-enduros.com/index.php/forums/74-7...ith-rex-s-pulsarless
yamaha-enduros.com/index.php/forums/perf...replacement-on-dt400
There's more threads on Rex's kits and products so anyone can research and decide what to buy... search here works good.
27 Aug 2019 06:13 #25
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Thank you for the links and comments Mark! Honestly I did do searches, I guess I just wasn't using the right verbiage to find what I was looking for but will say the search on here is better than on other forums.
27 Aug 2019 07:14 #26
After my experience with the moisture and corrosion under my RT stator cover a couple days ago, I was wondering? How well do the aftermarket electronic ignition systems hold up to the condensation moisture and corrosion it causes? Thinking that someday I may need to make this change also.
71 Z50 Minitrail
20 CB500X Halfrica Twin
21 CRF300l Rally
27 Aug 2019 08:12 #27
Well you would no longer have points in there to corrode thats an advantage.
The black box can be tucked out of harms way too.
A smear of silicone might help too. I dont think there is a gasket specified for that cover. I may be wrong.
27 Aug 2019 09:02 #28
I may have a similar problem, I have the white wire from the regulator/rectifier which connects to nothing and also a green wire from the stator also connected to nothing, Im having problems charging battery but rest of system spot on, was it a similar problem for you ? I am in contact with Marcus and he is being really helpful, I thought I had a system problem but more than likely as he says, wiring...don't I feel stooopid
cheers Keith
Last edit: 27 Aug 2019 11:11 by 750kr1.
27 Aug 2019 11:06 #29
  • AirborneSilva
  • Platinum Member
  • Platinum Member
What year/model to you have? I'm guessing the instructions are lacking which is another fear of mine, I'm pretty good with mechanical but wiring I'm not...
27 Aug 2019 11:42 #30
