I bought a 1979 rx125
Replied by Gr8uncleal on topic I bought a 1979 rx125
"Does anyone know how to remove the reservoir from the master cylinder body."
It looks like the same one as on a RD400 etc and my procedure outlined below assumes that it is.
There should be two screws in the bottom of the plastic reservoir - remove these. Then gently lever up the reservoir body by putting a thin, flathead screwdriver blade, or such like, between it and the base, going round each side a little at a time. It will eventually pop out and you will see that the reservoir has a circular "seat", with an 'O' ring on it, and this sits in a corresponding hole in the base.
Here's an image of one I've previously dismantled - I popped the screws back in the base for safekeeping.
Last edit: 20 Nov 2024 13:08 by Gr8uncleal.
20 Nov 2024 13:02 #21
  • s900t8v
  • s900t8v's Avatar Topic Author
  • Platinum Member
  • Platinum Member
Replied by s900t8v on topic I bought a 1979 rx125
Thanks. While it looks the same it doesn’t have the screws the body is just sitting there.  From what I can see there’s an o ring and I saw one article saying to twist it 90 but it doesn’t want to budge and I don’t want to break it.
I guess for now I’ll make do. But if it sticks or fails again and I have to spend another 50-60 on seals I will pursue dismantling it fully to clean it.
1976 Yamaha AG175 cafe
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
Last edit: 20 Nov 2024 13:38 by s900t8v.
20 Nov 2024 13:20 #22
  • s900t8v
  • Platinum Member
  • Platinum Member
Also another question. Are the mirror retaining nuts reverse thread.
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
20 Nov 2024 13:39 #23
Replied by RT325 on topic I bought a 1979 rx125
Mirrors should be lefthand thread on the right mirror only.
On thinking about it that doesn't make sense as would be undoing towards you so if not tight then the wind at 100mph on the RX could blow it around towards you.
Same with the left side with normal thread. But that's how it is down here on my RX's by memory.
20 Nov 2024 17:07 #24
Not sure what this is on but looks dangerous if yours fits in like that.
Think i'd avoid taking yours off!!.
When bleading up the empty system i mostly fill it from the bottom to the top then just blead it normaly once you have plenty of fluid up top in the reservoir. Works for me if its a grumpy one.
www.google.com/search?client=firefox-b-d...vid:m2MXwLzY6uk,st:0
20 Nov 2024 17:20 #25
Hey, i'm happy you found that inlet restrictor noise thingy.
Was annoyed i couldn't find mine to show you. Good one!!.
I'll go out to the shed & find mine now lol.
20 Nov 2024 17:28 #26
Replied by MarkT on topic I bought a 1979 rx125
Yes, mirror will "undo towards you"... designed to rotate loose if mirror strikes an object, right side is LH thread
20 Nov 2024 17:30 #27
Ahh, ok that make more sense than my theory lol.
20 Nov 2024 17:33 #28
  • s900t8v
  • Platinum Member
  • Platinum Member
Hey some updates
I rebuilt the master cylinder but it did not work because the tiny metering port was full of corrosion.
My reservoir is rhe style without the bolts holding the reservoir to the master cylinder. The reservoir simply twists off. The o ring is 39.7x3.5 according to another post on the forum but I lubricated mine with rubber grease and it went back on fine no leaks..
rhere was a blockage in the brake line but a few pumps fixed that and so I rebuild the caliper too. All fit  and working great brake is not binding or dragging and has a nice positive brake lever feel.
[img]https://i.ibb.co/12q5JpF/IMG-2921.jpg https://i.ibb.co/5W0vzdn/IMG-2894.jpg https://i.ibb.co/3R509pz/IMG-2888.jpg https://i.ibb.co/X4r6dLV/IMG-2923.jpg https://i.ibb.co/F6jJqTq/IMG-2945.jpg https://i.ibb.co/M6NNgB1/IMG-2977.jpg https://i.ibb.co/5FGrbTs/IMG-2974.jpg https://i.ibb.co/ZK1xgqH/IMG-2994.png https://i.ibb.co/QPJTqbB/IMG-2993.jpg[/img]
J [img]https://i.ibb.co/12q5JpF/IMG-2921.jpg https://i.ibb.co/5W0vzdn/IMG-2894.jpg https://i.ibb.co/3R509pz/IMG-2888.jpg https://i.ibb.co/X4r6dLV/IMG-2923.jpg https://i.ibb.co/F6jJqTq/IMG-2945.jpg https://i.ibb.co/M6NNgB1/IMG-2977.jpg https://i.ibb.co/5FGrbTs/IMG-2974.jpg https://i.ibb.co/ZK1xgqH/IMG-2994.png https://i.ibb.co/QPJTqbB/IMG-2993.jpg[/img]
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
The following user(s) Liked this Post: Badrul
Last edit: 25 Nov 2024 13:52 by s900t8v.
25 Nov 2024 13:44 #29
  • s900t8v
  • Platinum Member
  • Platinum Member
this photo shows the tiny metering port. I ran the master through the ultrasojic cleaner to get it clean without damaging the orifice size.
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
25 Nov 2024 13:56 #30
