The Beauty DT3 and the Beast DT1
- yamahahaha
The Beauty DT3 and the Beast DT1 was created by yamahahaha
I picked these 2 up this weekend. The DT3 yesterday and the 1968 DT1 this morning. I have never seen a clutch setup like the one on the DT1. I hope I get some answers from you guys.
The following user(s) Liked this Post: steam_biker, Badger52, Quartermaster35
03 Jan 2021 13:07
- yamahahaha
Replied by yamahahaha on topic The Beauty DT3 and the Beast DT1
1968 DT1...Custom green paint was an option I think
The following user(s) Liked this Post: Badger52
- yamahahaha
DT1.....Is the frame correct in the 3rd picture
The following user(s) Liked this Post: Quartermaster35
Replied by MarkT on topic The Beauty DT3 and the Beast DT1
That clutch actuator must have been an aftermarket part... has shown up on the forum several times.
03 Jan 2021 16:03
- yamahahaha
Thanks Mark, do you know what the advantage was IF ANY ? I have not been able to find another one like this on the forum
It's not a worm gear that breaks?
Someone here had one and even "re-engineered" it to use bearings in the pivots or something like that... others have had them too. I will look later if I have a chance.
03 Jan 2021 16:22
Got lucky... only took a few seconds searching "aftermarket clutch actuator DT1"
www.yamaha-enduros.com/index.php/forums/...restoration?start=10
yamaha-enduros.com/index.php/forums/cust...-race?start=40#52555
I know there were a few more.... but those are a good start.
- yamahahaha
Can someone verify if this is the correct exhaust for 1968 DT1 ?
04 Jan 2021 08:31
- Pedalcrazy
Replied by Pedalcrazy on topic The Beauty DT3 and the Beast DT1
Looks right from here. Should have an extension on the end held by a screw that goes through that hole near the outlet. Should be a rubber cover that seals the extension and outlet. I just purchased a rubber from EBay. I already had the extension. Surprised NOS Yamaha rubber seal was still available...still more of those on EBay I believe.
04 Jan 2021 09:49
- yamahahaha
Looking at the 3rd pic (frame) what is the purpose of the cut out that looks like a tank cup would slide into?
The other side of the frame DOES NOT have that
04 Jan 2021 15:57
