Transmission Oil Level?
  • RT3Sam
  • RT3Sam's Avatar Topic Author
Transmission Oil Level? was created by RT3Sam
So my transmission case states 1000cc Oil at the oil fill cap. But my dipstick shows the transmission case is way overfilled when I put 1000cc of oil in there. I put 500cc of oil in the case and the dipstick shows its at the correct level.
My question is how much oil are you guys putting in your transmission?
26 Oct 2020 06:45 #1
Replied by JimmyC on topic Transmission Oil Level?
Check it right after you run it. My DT400 with 1000cc in it read overful after the bike sat. Reads correct if I check it after I run it.
yamaha-enduros.com/index.php/forum/gener...179-dt400-oil-change
Last edit: 26 Oct 2020 08:45 by JimmyC. Reason: spelling
26 Oct 2020 08:23 #2
  • RT3Sam
Replied by RT3Sam on topic Transmission Oil Level?
Whats the book call for? I have an actual 1973 Yamaha service manual and it doesn't have oil capacity in it.
26 Oct 2020 08:56 #3
Replied by MarkT on topic Transmission Oil Level?
RT3 owner's manual (copy in the Tech Library) shows 1000cc or 1 US quart (quart is actually 946cc)
26 Oct 2020 09:44 #4
Replied by Pedalcrazy on topic Transmission Oil Level?
I see its already been answered a couple of times here but I've found the same thing until you run it, shut it off, let sit a little bit and check it. I even bought an NOS dipstick for my RT3 just to make sure I had the correct one...and I did. Make sure all the old oil is out (move the bike a little side to side at the end) and put in 1 quart. Done.
The following user(s) Liked this Post: MarkT, RT3Sam
26 Oct 2020 10:18 #5
  • RT3Sam
26 Oct 2020 12:25 #6
Owner's manual for your RT3 can be found in the Tech Library... links to library at top of most pages.
26 Oct 2020 13:02 #7
