DT3 Rear Lightbracket confusion
  • Jools
  • Jools's Avatar Topic Author
Replied by Jools on topic DT3 Rear Lightbracket confusion
I ordered most of the available mounting parts from CMSNL. The rear rubber was NLA but I found a NOS item here in Oz with the same part number which looks to be the dimensions you mention. Oddly enough the two shoulder bolts for the rear fixing are too long with the incorrect bracket. I'll wait for the correct bracket to arrive before I condemn them in case the bracket material is thicker.
The single front grommet I have with the dowel - I'm not so certain. I have a box of grommets so should be able to work something out for now.
The Older I get the Better I was !
1978 TZ750E, 1991 TZ250 3YL, 1973 DT3, 1991 TZR250 3XV
1989 TZR250 3MA, 1986 TZR250 2MA, 1983 RZ350 YPVS
1981 RD250LC, 1973 RD350, 1998 YZF R1, 1993 FJ1200
09 Sep 2020 14:13 #11
Replied by Rick C. on topic DT3 Rear Lightbracket confusion
Ah, a Kiwi.
I'm gonna need a " Players Program " to keep up on the Who's Who here ! :ROFLOL :beerchug
Last edit: 09 Sep 2020 14:28 by Rick C..
09 Sep 2020 14:26 #12
  • Jools
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=114237799659&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
  • Jools
The restored lamp and bracket turned up today so I can begin work again.
The bracket is finished in a grey primer, what should the finish be for the DT3 rear lamp bracket - silver ?
30 Sep 2020 15:58 #14
Replied by 1971DT250 on topic DT3 Rear Lightbracket confusion
Yes, same as the fenders and chain guard. I have a set done at the same time so they match.
30 Sep 2020 16:05 #15
  • Jools
Thank you for the details, I have given it a couple of coats of my closest silver and it looks ok. Sat on top of the painted rear guard it certainly doesn't stick out like the proverbial.
And now I find that I'm short of the top chain guard - impressed with another post on here I have knocked up a template with a view to making one up. My first attempt has got the basic spacing and rough pattern which now just needs a bit of visual adjustment of dimensions. Without a pattern to copy i realise I will never get it to be 100% accurate but it will serve its purpose.
02 Oct 2020 15:47 #16
Replied by shyted on topic DT3 Rear Lightbracket confusion
Jools,if you can get hycoat paint Ford moondust metalic is pretty bang on. Just make sure you use good lacquer over it.
03 Oct 2020 01:17 #17
  • Jools
I couldn't find that shade here, the only Hycoat appear to be special paints - HT etc.
I did find a light silver that doesn't look out of place. I used this on the upper chain guard I fabricated.
12 Oct 2020 16:10 #18
