DT3 Rear Lightbracket confusion
- Jools
DT3 Rear Lightbracket confusion was created by Jools
I'm slowly progressing with the refurb of my DT3. Its taken a lower priority of late but now parts are turning up its time to turn my head back on.
There has always been something niggling me about the rear light bracket. I suspect I have the incorrect one for the model, either that or the rear guard is wrong but as this fits the frame where it should I don't think this is the case.
If I align the bracket where the two lower mounting holes are, the single front mount is under the the rear frame loop and will crush the sub wiring loom where it exits the little tunnel. There is another hole in the guard with a grommet which i have always wondered what the purpose was.
I ordered one of the new "replacement" light brackets advertised online and its the same, plus with this bracket the reflectors foul the main body of the bracket so I made some stand offs.
It wasn't until I searched a few images of the DT3 online that I noticed that the bracket looks like the single front mount should attach where I noticed the unused hole lies.
Is it the bracket thats wrong or the guard, or something else........
Any guidance on this would be greatly appreciated.
Hopefully there is an attached image to show the problem.
The Older I get the Better I was !
1978 TZ750E, 1991 TZ250 3YL, 1973 DT3, 1991 TZR250 3XV
1989 TZR250 3MA, 1986 TZR250 2MA, 1983 RZ350 YPVS
1981 RD250LC, 1973 RD350, 1998 YZF R1, 1993 FJ1200
07 Sep 2020 19:00
Replied by Gr8uncleal on topic DT3 Rear Lightbracket confusion
That looks to me like the light bracket off the 1974 on models - eg DT360A.
The one for the 1972 and 1973 bikes is quite a bit shorter and a couple of photos of mine are attached - the first photo is my RT2 and the second my DT360A. Apologies for the dust and rust!
08 Sep 2020 00:48
- Jools
Replied by Jools on topic DT3 Rear Lightbracket confusion
Thanks for those photos. I wished I had queried this earlier as it would have saved me the cost of the new bracket that I waited a month for.
The Search is on..........
08 Sep 2020 02:49
- apex
- Content Contributor
Replied by apex on topic DT3 Rear Lightbracket confusion
The chrome bracket in your first post looks like one for an RD series bike, like RD350.
Allrighty Then
08 Sep 2020 06:57
It did occur to me that it was a little too shiny!
08 Sep 2020 07:47
- 1971DT250
Replied by 1971DT250 on topic DT3 Rear Lightbracket confusion
The following user(s) Liked this Post: Jools
08 Sep 2020 13:12
- Jools
It came with the box of bits with the bike.
What you say now makes sense as the rear guard is not chrome so it would look odd. I’m annoyed that the supplier of the new guard, still advertising online, is describing its fitment for DT/RT 1, 2 & 3 models.
I’ve contacted them to see what they will do, hopefully I can return it.
- Jools
Thanks for the link, I went ahead and bought this.
08 Sep 2020 13:25
- Pedalcrazy
Replied by Pedalcrazy on topic DT3 Rear Lightbracket confusion
The next thing is the rubber the bracket will sit on. You need the correct ones for your bike. There were basically two styles for the DTs and RTs. For your bike and the light you purchased (correct light) you need the thin rubber pad for the rear (2 holes) it is about 1/4 " thick. Then you need the extra thick grommet for the front (single hole). Some front ones take two different grommets combined to get the front up and rear down. With the correct rubbers your taillight should point back roughly parallel to the street. Using the wrong rubbers will have the light pointing more up than straight back.
08 Sep 2020 17:19
- Rick C.
Replied by Rick C. on topic DT3 Rear Lightbracket confusion
Here is a start to what Pedalcrazy was talking about.
P/N 308-84553-00-00
P/N 308-84553-00-00
09 Sep 2020 14:02
