Resurrecting Rick C & Brown Shoes' AT2
- t-bone
Replied by t-bone on topic Resurrecting Rick C & Brown Shoes' AT2
Beautiful! Can we have it back now?
The following user(s) Liked this Post: apex, Rick C.
- Rick C.
Replied by Rick C. on topic Resurrecting Rick C & Brown Shoes' AT2
( Wait til he dials it in first )
The following user(s) Liked this Post: apex, t-bone
06 Jun 2020 09:58
#32
- apex
- Content Contributor
Replied by apex on topic Resurrecting Rick C & Brown Shoes' AT2
Took Thing for a longish ride, as it was charging OK. It failed, limped it home 10 miles, running terribly. Problem 1 is it stopped charging again, no alternator output when full fielded, so ordered brushes from Singapore. The ones in the stator are at or past the wear bar...again funny the electric start works, and the alternator doesn't but the brushes are clearly done so must be replaced. Second problem is the timing went retarded. I should have replaced the points but I always feel if parts are working, able to set timing in the first place then OK? Not in this case, point contacts are wiped out and the rubbing block on the points are worn 0.3mm from the new, replacement comparison. New points are back in, and it's timed. Waiting for the brushes on the slow boat from Singapore...
Allrighty Then
The following user(s) Liked this Post: t-bone
09 Jun 2020 19:28
#33
- apex
Rear wheel...done. Front wheel in process.
Allrighty Then
The following user(s) Liked this Post: Devin, Rick C., t-bone, Steve F, JHof44
17 Jun 2020 06:59
#34
- apex
I'm always surprised by how redoing wheels make a bike pop. Every time! Now, to find a pipe guard. Lacing and truing wheels is true therapy, very satisfying, and completely worth learning the process.
Allrighty Then
The following user(s) Liked this Post: Devin, Rick C., t-bone, 2fishkev, Steve F, JHof44
19 Jun 2020 06:55
#35
- 2fishkev
Replied by 2fishkev on topic Resurrecting Rick C & Brown Shoes' AT2
Truth is spoken.......
19 Jun 2020 11:50
#36
- Rick C.
Hey Evan, do you have an oil pump cover?
I just went to storage and rounded up a ton of parts. Maybe I have one. Will check on that soon.
19 Jun 2020 13:57
#37
- apex
Rick I do have the cover. I have an oil pump to rebuild, so when that gets done & pump hung on the bike, the cover goes on. Thanks though!
In your stash, would you have a pipe guard for an AT2/3?!
Allrighty Then
- Pete-RT1
Replied by Pete-RT1 on topic Resurrecting Rick C & Brown Shoes' AT2
Hi Apex, how difficult is it to lace and true a wheel?
I haven't tried yet but I'm pretty handy as I'm a time served mechanical engineer and always looking to learn.
Yamaha CT1 007
Yamaha CT1-B The Doppelgänger
19 Jun 2020 14:33
#39
- Rick C.
Good deal !
will search for the pipe guard. I know I have a DT2/3. ( which won't fit, yeah...)
19 Jun 2020 14:34
#40
