Resurrecting Rick C & Brown Shoes' AT2
- apex
- Content Contributor
Resurrecting Rick C & Brown Shoes' AT2 was created by apex
Rick C & 'Ol Brown Shoe gifted me a disassembled, semi-complete AT2 a few years ago. I brought it home in the trunk & back seat of, I think, a Honda Accord? Feel free to remind me Rick. Anyway put it together with as much as was brought home, with as much "inventory" that I had on shelves. Assembled the engine with a conglomeration of spares I had, with what I drug home, and a well worn but OK cylinder & piston. Put it all together a couple years ago, and then, all the other bikes got in the way.
While it sat, I told my oldest, that it would be his bike when it's done. Some of you might remember Shane from a Gorman ride 5 or more years ago. We made a list of what it needs. He calls the bike Natalie. He likes Natalie Portman.
November of this year I scored a '71 CT1 that was 100% complete except engine. PERFECT!! Decided 2019's Holiday break was time to see if I could get it running, since I scored so many pieces from that '71 parts bike that would give me a huge leg up.
Decided to tackle the electrical first. I had an AT1 wire harness, and knew mod's would have to happen to use CT1 parts. The Starter/Alternator armature on the engine was a super clean one I've saved for years, clean and almost new brushes. Rotor to match from the same engine. Voltage Regulator came from a box of parts from another parts bike, connector was cut off. Just used Vintage Connections' bullet connectors to wire everything to the AT1 harness, no problem. Took of the cover to the Voltage Regulator and thoroughly cleaned the contact points, in hopes the thing works when the engine runs.
CT1 parts bike came with gauges, ignition switch WITH a key! Again, rewired the ignition switch 2 connector CT1 switch harness to match the 3 wire AT1 harness.
AT2 is 12V. CT1 is 6V. Had to replace all instrument bulbs, and the taillight bulb to 12V pieces in order to try to bring the lights alive. Got a Motodad rear fender bushing kit to set the CT1 rear fender up (original was crushed at the top tail light bracket mount), and mounted the tail light assembly from the CT1.
Then...got my old jumper cables from 1982, used the 12V battery from my kid's Xterra that we prematurely replaced (needed a starter instead :-7) hotwired the electrical and took a shot at seeing what worked...and it was EVERYTHING except the horn!
A video:
Next is cleaning up the engine side covers, clutch install, the rear brake install of lever, hub w/brake shoes and wiring the switch.
Allrighty Then
The following user(s) Liked this Post: Rick C., t-bone, Badger52
26 Dec 2019 21:06
- apex
Replied by apex on topic Resurrecting Rick C & Brown Shoes' AT2
Oh yeah. That super clean oil tank was not the one that came with it. Went to the Dixon M/C show in 2018 and a dude had a super SUPER clean oil tank, with emblems, for I think $25?!? Yes, it's on the bike. Nicest part on the whole bike by a large margin.
If anyone perusing this post has a gas cap to fit an AT2/CT2 or 3 tank, DM me please. Also looking for an AT2/CT2 or 3 seat pan, at minimum. KDI has the foam, so a pan would do me fine. Thanks!
Allrighty Then
The following user(s) Liked this Post: Badger52
26 Dec 2019 21:12
- apex
It runs! And it actually ran good, albeit using a donor car battery for 12V juice & an IV bottle for fuel. Working on the gas tank, electrolysis process, on the 6th anode now and have a nice sliver interior. Have a really ratty seat for now with a solid pan. Collecting fuel petcock rubbers this week, and a Motobatt AGM is on the way!
Allrighty Then
The following user(s) Liked this Post: t-bone, mdscott
03 Feb 2020 18:59
- apex
I've made some decent progress with the boy's AT2. Been riding it semi-regularly around town since the COVID thing started, and although ratty as hell it's a nice performer. I've worked through alot of the electrical, and it's a really good electric starter (but doesn't charge?), all lights work, chinese carb reproduction is doing OK after I made necessary changes...so all told, not bad!
Seat looks like crap, so pulled the trigger on KDI seat foam and cover, thanks Dave! that should be here next week.
Bought a Valspar paint kit off eBay that includes primer, base coat Metallic Orange for late model Nissan Murano & Rogue based off a recommendation by SlowPoke. I hate painting...well I hate sanding more than painting but I'm gonna give it a go.
So I could keep riding, put some other parts on the bike while the paint is going on. Nice to have spares.
Allrighty Then
07 May 2020 21:59
- Rick C.
Replied by Rick C. on topic Resurrecting Rick C & Brown Shoes' AT2
AH, thing 2. Now named after my buddy Barry's neighbor ( Funny note, 3 years ago Nat was backing up.in her mall cruiser down her driveway, and center punched my painter's Montero. She Carte Blanche'd that repair !! Super Bowl Sunday at Barrys.
been a while since I seen that bike . I may have some baby Pics.
Stellar Job there Evan !! Wonder if it would or ever surface. Cheers,
Shake it , shake it , like a Polaroid picture... those paint cans Brother !!!!
- Rick C.
07 May 2020 23:43
- apex
Ah, Thing 2 in all it's former glory. Thank you for that Hasbro cam pic!
Allrighty Then
08 May 2020 07:08
- mdscott
Replied by mdscott on topic Resurrecting Rick C & Brown Shoes' AT2
Apex,
I've seen the electrolysis removing rust from gas tank, what solution do you put in the tank?
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
08 May 2020 08:17
- apex
I use Soda Ash or PH up, available at any Pool store. 1/2 cup of the soda ash to 5 gallons of water. I run 2 anodes through each batch in the tank. This tank I did 6 anodes. I did the nuts & bolts, then shake shake shale to knock the flakes loose after the 4th anode, flushed it out, then finished with 2 more anodes. Turned out great!
Allrighty Then
The following user(s) Liked this Post: woodman5
08 May 2020 09:08
- t-bone
Replied by t-bone on topic Resurrecting Rick C & Brown Shoes' AT2
I wonder if thing one will show up someday?
AT1MX.
Strong work on thing 2 Bro.
That bike was rode hard and put up wet.
AT1MX.
