cylinder head bolts
Replied by RT325 on topic cylinder head bolts
Keen to know how that trick looking mag works when you get it running? Cheers.
11 Jul 2019 19:31 #11
Replied by bart.ives on topic cylinder head bolts
I am having the same issue with the cylinder head bolts back out on my 68 DT1-250. Did retorquing the head bolts work? Did you end up using Loctite? I have gone through a couple flat gaskets and now on a sandwich gasket that just started leaking during my ride yesterday. Retorqued this morning to 28.9 ft lbs. Any help from anyone is greatly appreciated.
Be Happy!
28 Sep 2020 11:08 #12
Replied by shyted on topic cylinder head bolts
Hard to say as i'm not there. In the past i had a DT 175 MX that did that.
I ended up replacing the studs and nuts as they were defective. They were only undone the once.
Maybe yours are the same. 18 or 28 lbs ft is nothing ,i think it's more down to the quality or their supplier when new as i haven't had problems with any others yet.
Last edit: 28 Sep 2020 11:24 by shyted.
28 Sep 2020 11:23 #13
Replied by Pillsbury on topic cylinder head bolts
It sounds like someone may have stretched your cylinder studs, once that happens it will not settle down again. You should replace the studs and the nuts.
1970 DT1-C Street tracker
1968 Honda CL90
1973 Honda CR250
1974 Honda MR-50
1966 Triumph Tiger Cub
1947 Mustang
1974 Suzuki TC185
28 Sep 2020 13:29 #14
