turn signal wires
- jsmith6752
turn signal wires was created by jsmith6752
DT360 what color wires do the turn signals plug into? They are both (front) black wires. A
12 Nov 2024 13:55
- jsmith6752
Replied by jsmith6752 on topic turn signal wires
what color wires do the front turn signals plug into inside the headlight? thanks
12 Nov 2024 13:57
- pabdt
Replied by pabdt on topic turn signal wires
The turn signals in headlight bucket have two wires coming from the switch on the handlebar. L=chocolate, R=Dark Green.
The connector is double barrelled and also feeds the rear turn signals.
I would recommend you test things with an ohm meter.
MAKE SURE you don't connect power to ground. I see you mentioned black wires. Are the turn signals aftermarket? If so, better post a pic.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
12 Nov 2024 21:32
- jsmith6752
as far as I know the signals are original with the black wires UI will look for the 2 colors you mentioned thank you
13 Nov 2024 06:49
Replied by Gr8uncleal on topic turn signal wires
Originals have Imasen cast/moulded into the inside and the lens respectively.
Yamaha probably standardised to black wires to enable the indicators to be used on either side.
I have occasionally seen a very short green or brown sleeve over a wire.
13 Nov 2024 07:06
- jsmith6752
I have found a yellow wire with bare end coming from the regulator inside the headlight housing. I don't have a clue where it goes...thanks
13 Nov 2024 08:42
- jsmith6752
they do have the sleeve
13 Nov 2024 08:44
"I have found a yellow wire with bare end coming from the regulator inside the headlight housing. I don't have a clue where it goes...thanks"
Yamaha recommend it is spliced into one of the blue wires from the clock illumination lights.
I found it easier to make up a pigtail with a single male bullet at one end and a double female at the other. The male bullet replaces one of the two existing blue males from the speedo and tacho illumination sockets, that go into the existing double female blue. Whichever male you removed goes into one of the pigtail females, and the regulator wire (should have a male bullet connector) goes into the other.
Make sure that the regulator is earthed properly.
13 Nov 2024 09:30
- jsmith6752
so you are saying the regulators yellow wire slices into the blue wires on the tac and speedo?
13 Nov 2024 15:14
- jsmith6752
I have no dash lights or headlight too.
13 Nov 2024 17:02
