1974 GT80 headlight, ring
- principal282
1974 GT80 headlight, ring was created by principal282
Yamaha part nmrs
lens assembly
338-84120-60-00
6V, 25/35 w
about 5 inches across, not the normal 5.75
Headlight rim
261-84315-61-00
lens assembly
338-84120-60-00
6V, 25/35 w
Headlight rim
261-84315-61-00
17 Jul 2023 20:15
Replied by MarkT on topic 1974 GT80 headlight, ring
I forgot to look for the parts I think I have. I will look tomorrow.
17 Jul 2023 20:29
- principal282
Replied by principal282 on topic 1974 GT80 headlight, ring
Thanks!! We are marching on, everything is stripped and the cylinder is going to the machine shop tomorrow!
17 Jul 2023 20:31
I have several of the 5" rings and buckets from the AT series... bucket has the square mounting holes for the rubber mounts and a high beam pilot light hole... I don't know if the little 80's had those. Chrome ring is the same part number though.
I found two 5" headlights with the "bayonet" bulb mount... one is old and used... the other is NOS. I don't know if I have the bulb or the pigtail... I have to look... too hot right now in the shed with lows near 90 and highs over 110.
18 Jul 2023 12:45
- principal282
Thanks for checking!!
so the each component is kind of separate, glass, ring, housing? Interesting. Guy could probably find a 6v bulb easier than a whole sealed beam setup
18 Jul 2023 18:21
Yes the sealed beam or this type lens/reflector with replaceable bulb has two little bolts and nuts that hold it into the rim. There is also a spring and adjuster screw setup... not sure if I have that hardware.
Your original rim and lens/reflector should be the same system?
I might have a bulb. I will look.
The following user(s) Liked this Post: Ht1kid, principal282
18 Jul 2023 20:22
