DT3 headlight
Replied by Makotosun on topic DT3 headlight
Post up some pictures of your headlight bucket. Something sounds odd. Thanks.
29 May 2017 06:16 #11
  • fossilrider
  • fossilrider's Avatar Topic Author
Replied by fossilrider on topic DT3 headlight
Like I said, I am pretty sure this bucket is from a '74-later or maybe '76-later Yamaha endure but can't guarantee this to be true. I do know it is a Yamaha item. Also I measured the unit on my '73 CT3 ( see pics) and it is even smaller than this one but has a different shaped bucket and rim both of these bikes are "bitsa" bikes, put together from what I could find but trying to stay as close to original as possible, so neither bike came with the headlight that is currently on it.
Last edit: 07 Jun 2017 17:56 by Makotosun.
31 May 2017 16:23 #12
Replied by run103 on topic DT3 headlight
get a 6 volt to 36 volt led out of china for 20 bucks and install it into the existing sealed beam. Bend the 8 tabs back on the stock sealed beam and bust the bulb and pull the back of the old bulb out and install the LED bulb into the old sealed beam done 5 of them now and they work like a charm and are actually very bright The original sealed beam fits the headlight frame nicer than new sealed beams Doug
07 Jun 2017 10:06 #13
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=162494354654&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Replied by Bob9 on topic DT3 headlight
i have thought about doing this but..........how do you go about busting out the back without shattering the whole thing?
bob noffs
07 Jun 2017 18:25 #15
Replied by Rverbeck on topic DT3 headlight
If anyone is going to attempt this LED surgery, please photo or video the process. This will likely help many of us.
07 Jun 2017 22:27 #16
  • fossilrider
I, like you, would like to see exactly how this is done. I just don't understand how you can break out a round hole in the back of a glass sealed beam without destroying the whole thing.? I am obviously missing something here.. I received my new wiring harness from DEET and plan to wrap this bike up within the next week or so, but still need to do something about this headlight issue. This has been a snag on a couple DT/CT projects for me.
05 Jul 2017 07:10 #17
Replied by yamahahaha on topic DT3 headlight
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=252683438229&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
I do agree strongly a video would greatly help many people ... When I first looked at mine I thought the same thing.... How do I get that darn thing out.. But it can be done
05 Jul 2017 10:20 #19
Replied by MarkT on topic DT3 headlight
Re-read post #12.
The original type headlight has what is basically a bulb crimped inside the reflector... kind of like a replaceable H4 except the original bulb is not meant to be replaceable. Once you bend back the crimping tabs and remove the stock bulb from the reflector (sometimes the bulb inside the reflector needs to be broken to remove it) you have a nice place to install a new bulb.
One challenge is the headlight is a parabolic reflector and there is what is called a "focal point"... basically the original filaments are placed in exactly the right place to focus the light beam pattern. I tried changing the original "crimped in" bulb once a few years ago with an H4 (not with an LED). The headlight was super bright. Unfortunately the light scattered all over the place and the pattern was terrible.
For many bikes with a 5 3/4" bulb without too much trouble you can replace the whole reflector with a new one that is made to take a replaceable bulb... there are several posts on this forum about it.
05 Jul 2017 11:31 #20
