1973 175 enduro CT-3, Headlight
  • harryo78
  • harryo78's Avatar Topic Author
1973 175 enduro CT-3, Headlight was created by harryo78
Hello, I'm restoring a CT-3 and am trying to locate a headlight Yamaha #251-84120-61-00. I'm nearing completion but some things are harder to find than others, headlight being one. I've read about converting over to a 12 volt system? any comments or help would be greatly appreciated! Thanks! John
03 Jan 2016 16:18 #1
Replied by Rita R. on topic 1973 175 enduro CT-3, Headlight
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=281301318944&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Replied by ksours on topic 1973 175 enduro CT-3, Headlight
How did you rig up the adjuster section? The light doesn't have an adjuster bracket. Did you just install the new light in the old bowl.
30 Jul 2021 12:02 #3
The sites are dead now. Do you have the numbers so I can do a search. Also do you happen to know the Diameter? I noticed the back of the bulb does not have a angle adjuster. Did you use the old bowl or just eliminate that part?
31 Jul 2021 13:40 #4
