Rear light side reflectors - can they be removed?
Rear light side reflectors - can they be removed? was created by Gr8uncleal
I have two round rear light lenses, each with a damaged round reflector as fitted to each side. The slight gap around the outside edge of the lenses makes me think that they are separate to the moulded lens, but I was wondering if, once they are glued in place, they can't subsequently be removed?
I would quite like to make one good lens out of my two dodgy ones!
Thanks.
Thanks.
17 Dec 2025 01:45
- Sneezles61
Replied by Sneezles61 on topic Rear light side reflectors - can they be removed?
I saw that on my 250A lense as well.
Now my thinking is heat. If glued or pressed in that could help.
So I don’t have an answer then…. /:
17 Dec 2025 05:55
Replied by Gr8uncleal on topic Rear light side reflectors - can they be removed?
Thanks Sneezles.
I considered heat a possibility, but thought that I'd ask here first.
17 Dec 2025 06:13
Bump.
Has anyone successfully removed a reflector lens?
Thanks.
Thanks.
14 Mar 2026 02:42
- automan
Replied by automan on topic Rear light side reflectors - can they be removed?
Yes, the outer shell acts like a lens.
They come off with old lights.
Why not sand and polish?
15 Mar 2026 11:06
On one rear light lens the side reflector has melted and on the other it is broken!
15 Mar 2026 11:20
