74 DT360 jug replacement?
  • dart451
  • dart451's Avatar Topic Author
74 DT360 jug replacement? was created by dart451
Hello friends,
    I've come up with a new dilema! Tried for days to get a broken stud out of the exhaust and could not get it out no matter what we tried. So, I bought a used DT360 jug, gaskets to replace the jug. Now, I do understand I have to measure the jug for my piston but I thought I'd ask the Enduro experts here what suggestions I might want to do to make it a successful exchange. Any suggestions will be greatly appreciated...thank you...
09 Dec 2025 07:43 #1
Replied by RT325 on topic 74 DT360 jug replacement?
Welcome, i guess the question is does your piston fit the jug & if so--how much clearance does it have. I'd just slide the piston in from the bottom untill ther skirt is in plus a little & minus rings & see what feeler blade fits in between skirt & cylinder. Easy initial check to see if ya in the ball park but if your clearance there is as little as 2thou or 0.05mm you'll be more than good. That's all without getting too technicaly worried at the moment.
i've had some bad broken studs to remove but have --so far-- a fail safe method where i arc weld a plate with hole a bit bigger that the broken stud & give it a good squirt with suitable rod & never fails to screw out. Ok, that's on a good day & not always that easy. In your case maybe take it to a competant tig welder to tig something to it as tig is more controlabe. Heat from welding will loosen it plus the plate to then turn it out. Does'nt matter if the alloy is compromised around it--noone gonna see it & i won't tell lol. Ps, i see ya not exactly new but anyway--welcome back.
Randomly googling & here's an excellent method using controlable tig to build up to the surface then tig on a bolt to turn--anything to turn, washer etc. I wish i had a tig after watching that. With yours it wouldn't matter if you had to drill the alloy away on top of your recessed broken stud to make it more accesable to weld onto. Just thinking back 50 years i guess yours has those "alway fail" 6mm studs stepping up to 8mm on the outside. Why the $%$% they used those i'll never know. But if that's the case & you 'do' get it out then tap it to 8mm for a normal stud.,
The following user(s) Liked this Post: Snglsmkr, pabdt, Ht1kid
Last edit: 09 Dec 2025 16:47 by RT325.
09 Dec 2025 16:08 #2
  • dart451
Replied by dart451 on topic 74 DT360 jug replacement?
Thanks for the reply. I do have a Primeweld 225 tig machine but it's not very mobile so unless I took the jug off, it would be most difficult for me to tig. We did try migging a nut on the end of it but both times it broke off. I agree TIG has better prenatration! And lastly my son tried drilling out more and got more aluminum drilled than the stud! So, that's the reason for me getting another jug. I'll just take the rings off and see how much ring gap I have in the newer jug. I was wondering if I should hone the cylinder and get a new set of rings but won't know until I get measurements...
09 Dec 2025 16:43 #3
Thanks for the reply. Please keep us updated when you can. I edited my post there a couple of time. Till later. Cheers. ps, thought maybe had the cylinder off & yes easier to get at for sure.
09 Dec 2025 16:50 #4
  • dart451
Does anyone know if the head and jug can be removed without removing the engine from the frame?
09 Dec 2025 16:54 #5
Replied by pabdt on topic 74 DT360 jug replacement?
I have had mine off several times in last month for "testing".
To remove, simply remove tank and exhaust first. Tank has 17mm nut.  Note: 13 mm on head, 13mm under the seat holding center of exhaust, 2 - 10mm caps nuts holding muffler on.  Leave decompression valve on and remove to transfer after cylinder off of engine, 17mm also.
There are 6 nuts for the head, 13mm. There are 6 jug sleeved nuts, 13mm. I usually torque the jug on at 25 ft-lbs and the head at 15 ftlbs.
HINT: I use a stemmed (example) magnet to pull washers and nuts out.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
Last edit: 09 Dec 2025 17:26 by pabdt.
09 Dec 2025 17:20 #6
  • dart451
Question? The used jug that's coming is supposed to be 80.06mm bore. I measured mine and mine is about 80.00. Do you suppose if I honed the jug lightly and put new OEM stock rings on my piston, would I be in the ball park? I believe this is about .060 thousandth...
13 Dec 2025 16:32 #7
  • dart451
Replied by dart451 on topic 74 DT360 used jug installation
Question? The used jug that's coming is supposed to be 80.06mm bore. I measured mine and mine is about 80.00. Do you suppose if I honed the jug lightly and put new OEM stock rings on my piston, would I be in the ball park? Once it gets here I'll have better measurements...
Last edit: 14 Dec 2025 14:45 by MarkT. Reason: Moved into original thread.
14 Dec 2025 14:17 #8
Replied by MarkT on topic 74 DT360 used jug installation
Please don't start new threads with the same question.  It really creates confusion.
You're asking a question nobody can answer as it's difficult to measure a bore accurately without the correct tools and experience.  (A standard caliper usually is not very accurate) And you're relying on a measurement a seller took.
Best advice if you don't have a bore gauge is get the cylinder and see how your piston fits.  If you can get more than about a 0.003" or 0.004" feeler gauge between the bottom of skirt and bore, it will rattle like hell.
Stock bores tend to be very, very close to spec diameter, say 80.00mm.  Then the stock piston is slightly smaller than the bore size say 79.94mm.
The following user(s) Liked this Post: RT325, Snglsmkr, nhsteve
14 Dec 2025 14:44 #9
  • dart451
Thanks for the feedback...I didn't think anyone would see an old post which is why I posted new. So, I won't do it again. Thanks for the information also. It should be pretty easy to figure out what clearance I have when the new jug comes. However, I think I will probably see if I can get the old stud out now that I have the jug off and can get at it better...wish me luck!
14 Dec 2025 15:07 #10
