RT3 Fork Cylinder Bolt Spinning
  • Pinbill
  • Pinbill's Avatar Topic Author
RT3 Fork Cylinder Bolt Spinning was created by Pinbill
Hello,
I am assembling the forks for my RT3 after replacing the seals. On one side the bolt on the bottom that threads into the cylinder valve wont torque. The inner valve assembly spins even with the spring installed. The other side tightens. Is there a tool or method to hold the assembly inside the tube to prevent it from spinning?
Should I put the tight end of the spring down or up? The tight side was up when I took it apart.
Thank you for your help,
Bill
08 Dec 2025 11:44 #1
Replied by Swoop56 on topic RT3 Fork Cylinder Bolt Spinning
Are you compressing the fork as well , as you tighten the bolt ?
08 Dec 2025 11:47 #2
  • Pinbill
Replied by Pinbill on topic RT3 Fork Cylinder Bolt Spinning
Yes, I leaned on it as much as I could. I checked the threads and screwed the bolt in with the fork disassembled. The bolt screws in nice.
08 Dec 2025 19:18 #3
Replied by darinm on topic RT3 Fork Cylinder Bolt Spinning
Doing it by hand? In my experience using an impact gun and compression of the spring will get the job done
1972 Yamaha CT2 175
1972 Suzuki TS185 Sierra
1997 BMW R1100R
2013 Yamaha XT250
The following user(s) Liked this Post: automan
08 Dec 2025 19:59 #4
  • Pinbill
You got it. The impact worked. Thanks for the help. I try not to use air tools on the old stuff. This time it was the ticket.
If anyone from the future is reading this, some heat on the fork tubes helped get the seals out without beating them up. My seals had been in there for a while.
I am leaning towards the loose end of the springs downwards. I am only riding on the street so it may not make a big difference. If I am making a huge mistake please let me know.
I appreciate the input. Thanks again. Happy motoring.
09 Dec 2025 09:32 #5
Replied by Badrul on topic Re:RT3 Fork Cylinder Bolt Spinning
i made a special tool for locking those fork piston from turning. Long T handle with their ends fit onto the shock piston head. Best way is to identify which types you have there.Using torchlight to see them down there.
I've come with 3 different kind of the shock pistons head. The allen bolt from beneath usually been loctide,so one needs to heat up them first.
insert the long T handle and turn the shock upside down,i just placed them in the drain as i dont have a table vice, my T handle they wont be turning around in the drain .After making sure the T handle is secure on the piston i give a good wack on the impact screw driver. Usually a good of 3 wacking on them will lossen the allen bolt.
Sent from my RMX1911 using Tapatalk
09 Dec 2025 18:20 #6
