74 DT 360 Cylinder ID
  • pabdt
  • pabdt's Avatar Topic Author
  • Online
  • Platinum Member
  • Platinum Member
74 DT 360 Cylinder ID was created by pabdt
In the process of trying to find what is causing a vibration in my engine I have tried several tests.  One was a different cylinder/piston combo.
The second cylinder has the numbers "44500" across the base, however my other cylinder does not. no improvements were noted.  Now looking at bearings a a potential problem.
In any case, are the cylinders labeled 44500 the same as those non-labeled?
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
11 Nov 2025 23:35 #1
Replied by RT325 on topic 74 DT 360 Cylinder ID
Engine mount bolts must be tight, that's always my first thought. 360A have bonded rubber mounts top rear, are they still in one piece.
12 Nov 2025 00:05 #2
  • pabdt
  • Online
  • Platinum Member
  • Platinum Member
Replied by pabdt on topic 74 DT 360 Cylinder ID
Engine is torn down and looks like I may have found a possible problem... DRIVE AXLE BEARING.
More to come...
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
12 Nov 2025 00:49 #3
Replied by MarkT on topic 74 DT 360 Cylinder ID
Have the crank checked for alignment/true.
In my experience, the difference between a crank that is just barely "within spec" and one that is pretty much perfect can be felt in terms of vibration.
12 Nov 2025 08:01 #4
