locking gas cap..missing key
- ZEFER
locking gas cap..missing key was created by ZEFER
So I have a fuel tank from a 74 DT-250-A it a locking
any one have any sugesstions ? I am going to SH-can the old cap if or when i get it off and replace it with a non locking cap
30 Oct 2025 10:19
Replied by Gr8uncleal on topic locking gas cap..missing key
Have you tried the key for your ignition switch in it? I've just had a look at mine, as well as pictures online of a couple of others, and the lock isn't numbered. It must therefore be very basic, with any numbered key from a 1974 DT opening it (looks like that lock style was one year only). Or, if you are close to a locksmith, you could take the tank there and see if they have a key that fits it.
30 Oct 2025 10:41
- pabdt
Replied by pabdt on topic locking gas cap..missing key
You must not have an ignition key? I have analyzed those locks and found that the fuel tank lock opens on the "base" part of the key. Tested and found, an UNCUT key will open the tank and is not locked as indicated in prev post.
1969 Yamaha CT1 175
1969 Yamaha DT1S 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
1974 Yamaha DT125A
30 Oct 2025 12:51
- Sneezles61
Replied by Sneezles61 on topic locking gas cap..missing key
Maybe just my stuff, but a screwdriver works too.
The following user(s) Liked this Post: MarkT, pabdt
30 Oct 2025 17:40
- ZEFER
Replied by ZEFER on topic locking gas cap..missing key
So I tried the screwdriver and it worked !
01 Nov 2025 12:17
I love a fix that is cheap as chips!
01 Nov 2025 12:57
- ZEFER
The way this thing was buggered up I never gave the most simple thing a shot
thanks for that…any leads on whether the lock cylinder can be replaced ?
01 Nov 2025 15:31
- loner
Replied by loner on topic locking gas cap..missing key
On some gas caps there is a numbered code ie. 279. There are online services that can make a key that fits for about $10 USD. I have had success getting working keys for my bikes. I don't know if that is only for vintage bikes only. Good luck. I see that you have applied "the screwdriver method" with success. Sorry for the late response, as I have experienced difficulties with my computer.
02 Nov 2025 07:36
"The way this thing was buggered up I never gave the most simple thing a shot
thanks for that…any leads on whether the lock cylinder can be replaced ?"
Given the previous comments, I would suggest that it is not a true lock, in that there are no levers present. There will therefore be no cylinder to replace.
02 Nov 2025 08:08
- ZEFER
There is or was a lock cylinder and the lock itself has been Fkd up as it is right now I can unlock it with a flat blade screwdriver…which is fine for now though I would really like to find the correct undamaged part
any leads
any leads
03 Nov 2025 07:47
