Base idle screw and mixture screw settings. AT3 - 125cc
  • custombolt
  • custombolt's Avatar Topic Author
Big screw idle? Small screw mixture? 1.5 out?
13 May 2025 13:42 #1
Answer is yes--in theory-- providing everything is good. Float level, clean jets & airways, airfilter. The list goes on-- needle jet not worn as can suck past there even at idle in a severe wear case. But I see it's an at3 so the miniature Oring sealing the bowl onto the needle jet setter is critical.although would more come into play as revs rise. So short answer lol--yes 1.5 turns out. Then speed screw as desired. Be sure your choke is in the off possition too.
13 May 2025 14:04 #2
  • custombolt
Started up at 1.5 out. Love the electric start!
14 May 2025 09:15 #3
