DT360
- jsmith6752
DT360 was created by jsmith6752
very hard to start without starting fluid carb is rebuilt and all passages are open its CDI with a great spark I have not checked the reeds yet any suggestion will be helped
27 Apr 2025 08:26
Replied by Gr8uncleal on topic DT360
Did you check that the tiny hole in the float bowl is clear?
Jet is at the bottom of the orifice on the back edge of the bowl - see generic image below. Spray carb cleaner etc down there and it should flow out of the jet at the bottom.
- Schu
Replied by Schu on topic DT360
Try holding the throttle wide open and give it a kick.
I have two DT360As.
One starts normal with choke and absolutely no throttle. (Cold start)
The other will ONLY start if I hold the throttle wide open with choke. (Cold start)
Be prepared to release the throttle as soon as you swat it or it screams to life!
Both start normal once warmed up, meaning no choke, no throttle.
I will figure it out eventually because I fear kickbacks with the full throttle method, but it hasn’t yet.
I have two DT360As.
27 Apr 2025 09:33
- jsmith6752
Replied by jsmith6752 on topic DT360
Thanks for your responses. As far as the bowl I don't see a jet in there.
27 Apr 2025 09:38
"Thanks for your responses. As far as the bowl I don't see a jet in there."
I can assure you that their will be one in there, just as in the photo. If there isn't, then you've got the wrong float bowl!
I've cleared blocked ones with 0.4mm copper wire.
27 Apr 2025 09:44
Replied by MarkT on topic DT360
Starter Jet is pressed in to bottom of well "1" and gets fuel through hole "2"
27 Apr 2025 12:49
- jsmith6752
I guess some how or some one removed it. I guess I will need to find a bowl or a jet.
27 Apr 2025 14:11
