3 POS KEY SWITCH ANALYSIS
- pabdt
3 POS KEY SWITCH ANALYSIS was created by pabdt
So, decided to have some fun last night. Analyzed a 3 pos key switch to see which pin goes where and how power is applied. Note, I have never used this switch on a bike, but have seen it several times in wiring diagrams and thought this might help others visualize how it works. If you see error(s), please let me know and I'll fix.
Bottom of switch.
Opposite side of switch:
in order to connect wires, this piece faces part in prev pic and is rotated by key switch.
the triangles are represented by part in prev pic. This shows the key switch in
OFF position
DAY position
NIGHT position
in case you break a wire and forget, where it goes, look carefully at the plate. Its written on it.
Bottom of switch.
OFF position
DAY position
NIGHT position
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
The following user(s) Liked this Post: MarkT, RTD2, swm, Swoop56, Schu, Wessi, Ht1kid, alnarv, Sneezles61, Tinkicker, pahiker
20 Sep 2024 09:24
Replied by MarkT on topic 3 POS KEY SWITCH ANALYSIS
Very nice job! Love it!
Just be aware that there may have been more than one supplier or version of switches as sometimes the layout is different even though the switch functions are the same.
Also, there is a connection chart on many of the wiring diagrams that clearly map which wires connect with key in each position
20 Sep 2024 09:36
- Sneezles61
Replied by Sneezles61 on topic 3 POS KEY SWITCH ANALYSIS
Thank you for making the effort and time to do this!
To me, it’s amazing how complicated, yet simple these switches are. I never saw the wire label on the back, near the lugs.
21 Sep 2024 05:24
