Looking for pics measurements of vm30ss carb
- pabdt
Looking for pics measurements of vm30ss carb was created by pabdt
Looking for pics of vm30ss carb. Inlet , outlet, everything you have.
measurements on inlet and outlet would be interesting.
Looks like I may have to use my vm 320-33 carb initially for my resto dt360.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
- pabdt
Replied by pabdt on topic Looking for pics measurements of vm30ss carb
while surfing ebay, I came across a carb that was advertised as a "Rt1 360 Carburetor". After looking at it, I realized it was probably a
VM30SS. I got it today, pics below. It looks like an OEM VM30SS, including stock jetting. The carb is in such good shape, I think I can run it nearly as is but plan to clean it, check float, first. Need lotto ticket...unicorn found.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
The following user(s) Liked this Post: Tinkicker, pahiker
Replied by MarkT on topic Looking for pics measurements of vm30ss carb
If original Yamaha, it should have numbers stamped in it across the choke boss on that model if I remember correctly. You should see it across the front of carb
20 Sep 2024 17:52
- pabdt
Thank you Mark. I found this: 445 61
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
20 Sep 2024 18:49
- pabdt
Attached to the carb was an original throttle/oil pump cable. The dimensions were pretty much exact to the HVCycle's throttle cable I already put on.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
20 Sep 2024 18:54
That's a 1974 DT360 carb (445)
Original jetting spec was stamped "60" according to the documents I have.
61 was likely a mid-production revision of some type.
20 Sep 2024 18:59
- Sneezles61
Replied by Sneezles61 on topic Looking for pics measurements of vm30ss carb
Wouldn’t the older ones be flange mounted? That one looks like it’s clamped.
21 Sep 2024 05:32
Replied by Gr8uncleal on topic Looking for pics measurements of vm30ss carb
1974 DT360A is one of the newer ones!
That is the correct carb.
21 Sep 2024 07:51
