Steel seat base - tapped for hinge/latch bolts?
  • Phyllo
  • Phyllo's Avatar Topic Author
Can anyone tell me if the steel seat bases on the earlier bikes (mine's a '73 250) are tapped for the hinge and latch bolts?  Or is there a nut on the other side?  I want to remove my latch, but not if the base isn't tapped...
Thanks!
31 Aug 2024 17:33 #1
There is a nut welded to the base on the other side .
However if the seat cover has been damaged allowing water in , corrosion on the bolts could be an issue .
I've snapped off a few trying to remove them .
Equal measures of penetrating oil and patience might be required .
Last edit: 31 Aug 2024 19:11 by Swoop56.
31 Aug 2024 19:08 #2
Yes, very likely the bolts will snap if corroded.
31 Aug 2024 19:13 #3
  • Phyllo
Thanks guys, I appreciate the quick responses!
31 Aug 2024 20:42 #4
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic Steel seat base - tapped for hinge/latch bolts?
It's quite straightforward to drill out the snapped bolt up to M5, and then tap a new M6 thread. Even easier if the seat is apart and you can get the base under a pillar drill.
31 Aug 2024 22:45 #5
  • Phyllo
Mine's pretty clean, no apparent corrosion. I sprayed a bit of Kroil, just in case. Going to try them later today. I am trying to save the original seatcover - that was the driver of my question, so really don't want to take the whole thing apart...
THanks for all input!
01 Sep 2024 06:27 #6
The corrosion can be on the bolt threads protruding above the nut . If the bolts loosen a bit ,
keep adding the Kroil and work them back and forth , and hopefully you can remove them intact .
01 Sep 2024 14:04 #7
