AT 2 125 engine into CT2
- djetmb
AT 2 125 engine into CT2 was created by djetmb
I have a chance to buy an AT2 125 engine in good condition and wanted to swap into my CT2. Why you ask?
12 volt electrics for one. I would also do the 175 barrel/piston swap. I've done that before and have all the parts so that's easy.
Yes, the electric starter struggles but it's a fair trade off.
I assume the AT battery box will fit the CT?
I'm retired so these projects help keep my sanity.
There is the Vape 12 volt kit too. Anyone done this conversion?
Thoughts and comments? Thanks for your attention.
21 May 2024 18:11
Replied by RT325 on topic AT 2 125 engine into CT2
I'll watch with interest as i love projects like your one. Hope it all goes to plan.
21 May 2024 18:20
- RTD2
Replied by RTD2 on topic AT 2 125 engine into CT2
I see nothing that says this won't work. I am certain that you will make the 12V battery box work, that should be the only hang up.
21 May 2024 19:55
Replied by MarkT on topic AT 2 125 engine into CT2
You'll need to swap pretty much the whole electrical system.
The following user(s) Liked this Post: RTD2
21 May 2024 21:58
If ya not worried about electric start & just ignition, you could run a very small 12 volt battery & back the charging off to a minimum.
I'm forgetting you're probably running lights.
22 May 2024 00:04
