12volt battery for 69 dt1b
Replied by DVM on topic 12volt battery for 69 dt1b
I made a conversion for replacing the old Yamaha headlight to LED headlight. It works GREAT on CT's, DT's, and RT's.
Search my old posts.
I was going to make conversion kits but I am getting away from vintage Yamaha things
Last edit: 06 Jan 2024 13:24 by DVM.
06 Jan 2024 13:22 #21
Replied by AirborneSilva on topic 12volt battery for 69 dt1b
I installed the Vape 12v system on my 76 DT400 and love it.  I had a hard time finding a battery to fit, I took a chance on a battery from Amazon (link below), and it's worked great so far.  Hope this helps!
12v battery
06 Jan 2024 16:02 #22
  • pmb
  • pmb's Avatar Topic Author
Replied by pmb on topic 12volt battery for 69 dt1b
Because I can’t make up my mind, I now have two growing collections of parts. All stock setup or LEDs and try the 12 volt route.
I really appreciate all the options and opinions.
It’s going to be a few weeks before I can get the time to tinker around and see what I like. When that happens, I’ll check in with the results and any good stories of what I tried and what happened. Hopefully no stories about “Letting the smoke out!”
Cheers.
Pmb
06 Jan 2024 17:37 #23
Replied by MarkT on topic 12volt battery for 69 dt1b
If you look on ebay you might find a kit like this for Japanese wiring?
whereisbobl.com/tiger/smoke.html
The following user(s) Liked this Post: Schu, Ht1kid, Pete-RT1, Knutco11, Sneezles61
Last edit: 06 Jan 2024 18:50 by MarkT.
06 Jan 2024 18:49 #24
Replied by Sneezles61 on topic 12volt battery for 69 dt1b
Ha! Was no way I could read all that… Laffing so, off the rest room…
Sneezles61
06 Jan 2024 19:38 #25
Replied by Pete-RT1 on topic 12volt battery for 69 dt1b
Found a photo showing how bright the LED was.
If I had a more I would use them again, as they certainly make the bike more visible, it was simply the mechanical failure that caused me to swap it out.
My CT1-B now has a pattern DT175MX headlamp unit form Yambits, which has a replaceable filament bulb, this also works fine.
Both bikes have a voltage regulator fitted, which is an upgrade I'd certainly recommend.
Best of luck with whatever you do.
Yamaha CT3 (in bits)
The following user(s) Liked this Post: Ht1kid, Knutco11
07 Jan 2024 06:54 #26
Replied by Knutco11 on topic 12volt battery for 69 dt1b
Rt1-pete, I do wonder if they have a rectifier built into them.  I'm sticking to my guns on the leds, only way they work right is with a rectifier.
An added rectifier, not the one that is your led light.  To clarify.
Last edit: 07 Jan 2024 08:01 by Knutco11.
07 Jan 2024 07:21 #27
This might have been said before but an LED is a "rectifier".
But most are not designed to handle the power of "rectifying" the AC to DC in this situation so they can burn up.
07 Jan 2024 07:43 #28
Rectifier= diode.  Led= light emitting "diode."  Alright I gave er my best, I'm leaving it be now, lol
07 Jan 2024 07:57 #29
