Eliminate bead locks?
- seven4eight
Eliminate bead locks? was created by seven4eight
Unfortunately the search function is not working for some reason.
Has anyone else removed the bead locks on the factory rear wheel and plugged / sealed the holes? Bike is a 1973 DT3, has (2) factory beadlocks. Thanks
15 Dec 2023 19:15
Replied by RT325 on topic Eliminate bead locks?
Shouldn't be a problem for the road. Just get a rubber bung or something that isn't protrusive sticking up.
www.aliexpress.com/item/1005004228738104...27&afSmartRedirect=y
- Swoop56
Replied by Swoop56 on topic Eliminate bead locks?
I've heard of people putting a 6mm screw through the rim , and a nut to secure it .
The following user(s) Liked this Post: seven4eight
16 Dec 2023 01:03
Replied by MarkT on topic Eliminate bead locks?
I use Motion Pro lite locs.
16 Dec 2023 05:15
- turbodan
Replied by turbodan on topic Eliminate bead locks?
No problem at all to leave them out. Surely don't need two of them in there.
17 Dec 2023 20:24
- asco
Replied by asco on topic Eliminate bead locks?
If you truly enjoy pushing your motorcycle, because the valve stem has been torn off of course you can remove the tire tube wheel locks. There is a reason that there are two wheel locks on the rear tire and one on the front. If you get into a situation where you have to give it full throttle and let the clutch out to avoid a car smashing into you maybe it’s perhaps worth it not to have it but under normal circumstances I would always run the wheel locks and I would recommend running the wheel locks because they’re put there to keep from tearing off the valve stem Schrader valve.
a
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
- Badrul
Replied by Badrul on topic Re:Eliminate bead locks?
I cut old tire tube little further around their air valve and placed them there , use little loctite on the caps (coloured alu. air caps for easier notice next time when re-air the tire)
Sent from my A37fw using Tapatalk
19 Dec 2023 07:10
- automan
Replied by automan on topic Eliminate bead locks?
Bead loks for low pressure tire pressure on mx bikes with high torque.
cliff
cliff
The following user(s) Liked this Post: turbodan, Tinkicker
19 Dec 2023 18:43
- seven4eight
Replied by seven4eight on topic Eliminate bead locks?
To reply to Asco, how is it possible I've ridden a DR650 20k plus miles and never ripped a valve stem out? It doesn't have bead locks.
I found 2 8mm flat phillips style bolts at hardware store, sealed on both ends with a rubber washer and a nylock nut. Seems to work great. Thanks
22 Dec 2023 19:24
Modern bike most likely has aluminum rims, almost certainly with sharp serrations inside the rim lips to help keep the tire from slipping...
Not quite the same as a very slick chromed steel wheel.
In any case, if you don't run low pressures you'll probably be fine.
22 Dec 2023 21:27
