Parts List
- laup
Parts List was created by laup
hi all, after parts list for Euro 75 dt250 that has the extra park light in headlight shell, or even better wiring diagram for it please, help appreciated, thanks
07 Jun 2023 12:13
Replied by Gr8uncleal on topic Parts List
I don't have exactly what you're after, but I might have bits and bobs which, when looked at together, might help.
Just in case you weren't sure, if the park light has just a single blue/red wire (male bullet connector), then this connects with the female blue/red from the ignition switch and the light earths direct from the headlight (which shouldn't be rubber mounted for this to work). If it has a blue/red and a black, then the blue/red connects as previously and the black goes into one of the multi female blacks in the headlight bowl.
07 Jun 2023 12:44
- laup
Replied by laup on topic Parts List
Thanks Gr8uncleal for help, issue is i had to get after market replacement and wires for side light are a brown/white and green, headlight itself is fine. just thought that as it had side lught may as well stick with it rather than just having the hole in the shell, thanks
07 Jun 2023 12:49
OK.
As you've probably sussed, whichever wire goes up the centre of the bulb holder is the positive and should go to the blue/red from the ignition switch. The other one goes to the black. Saying that, it's a standalone circuit and so won't matter which way you wire them.
PS - It looks like all of these aftermarket lights are wired in Honda colours, and yours is no exception (green = earth and brown/white = tail light).
- laup
thanks Grbuncleal, wiring is not my strong point at all, been studying the forums for hours on the tail light dimming when flashers on issue but think i got there lol
07 Jun 2023 22:31
