DT3 front fender stripe
  • Phyllo
  • Phyllo's Avatar Topic Author
DT3 front fender stripe was created by Phyllo
Does anyone have a recommendation for graphics? Specifically, I’m looking for the front fender stripe for my DT3. I haven’t measured yet, but it may need to be longer than stock as I went to a 74 YZ high fender. I know I can check with local vinyl graphics shops, just thought I’d see if there’s any good suppliers that specialize.
18 May 2023 09:49 #1
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic DT3 front fender stripe
Personally, I wouldn't bother with the stripe for a high fender.
Diablo in Canada do a repro for the standard fender - I'll measure my unused one in a moment and then post the size (it'll be no good to you, as I'm in the UK).
Update.
Total length is 657mm.
Total width is 28.5mm.
Width of black central band is 19mm.
Width of each white outer band is 4.75mm.
These measurements were taken from my Diablo repro, using a ruler and metal tape measure, through the semi transparent sealed protective cover!
Last edit: 18 May 2023 11:08 by Gr8uncleal.
18 May 2023 10:46 #2
  • Phyllo
Replied by Phyllo on topic DT3 front fender stripe
I just kind of like the stripe. Since I went away from the original low fender, just thought it would give the high fender kind of a finishing touch… I have the low fender tucked away and can measure it. Pretty sure the new one is longer, so probably just better off going local for a custom.
18 May 2023 11:03 #3
  • Gr8uncleal
In case you missed it (we might have been typing at the same time!), I have updated my first post.
18 May 2023 11:09 #4
  • Phyllo
Thanks!
18 May 2023 13:48 #5
Replied by hcdiiiga on topic DT3 front fender stripe
I got these off of Ebay, I really didn't check them for accuracy though, others can weigh in if there is something wrong.
19 May 2023 05:26 #6
  • Phyllo
Wow, nice! Thanks! I took a look at my original fender last night and was a little surprised at how off-center the black is in the white. I’d say one white side might be 1/16” less than the other. Never noticed it before…
19 May 2023 06:01 #7
  • Quartermaster35
  • Quartermaster35's Avatar
Replied by Quartermaster35 on topic DT3 front fender stripe
I ordered the front stripe for my CT3 from Diablo and it turned out well & looks like the original.
1973 Yamaha CT3 175
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1980 Yamaha 175 Tri-Moto
1969 Yamaha DT1 250
1981 Yamaha XS650 Special
1982 Suzuki GS550ES
1982 Honda 250R
1984 Honda Nighthawk "S"
2005 Kawasaki KLR650
19 May 2023 09:38 #8
