Site Feature Challenged
  • RT1
  • RT1's Avatar Topic Author
Site Feature Challenged was created by RT1
I have been doing my best to research for any information regarding a successful changeover to 12v LED Headlight on RT / DT.
I'll be installing a VAPE system and I'm looking to upgrade the lighting at the same time.
Using search word(s) "LED Headlight" and "LED" gets me nothing but 1680 posts about every topic under the sun.
I must be doing something wrong, but what?
How do you conduct a successful search?
Or, can someone just tell me what will work?
'68 DT1, '71 RT1, '71 JT1 (x2), '72 AT2 (x2), '74 DT250A, '75 XS650, '54 BSA C11G, '70 Honda CT70, '73 Hodaka Combat Wombat, '05 Moto-Guzzi Breva, '15 Triumph Tiger, +++
"We are mere custodians of mechanical things. Our job it to care for them, improve them and pass them on to others.” - Peter Egan
27 Apr 2023 09:03 #1
Replied by MarkT on topic Site Feature Challenged
Add more/different keywords. Also it's VERY helpful to put a phrase in quotes... otherwise you're searching for any post that has the letter sequence "led" (even within word!) or headlight.
Try "LED Headlight" WITH the quotes.
I'd try "headlight replacement" or "replacement headlight"... again WITH the quotes
The following user(s) Liked this Post: RT1
27 Apr 2023 09:31 #2
Replied by Gr8uncleal on topic Site Feature Challenged
Also, use the search button on the lower of the toolbars.
27 Apr 2023 09:58 #3
  • RT1
Replied by RT1 on topic Site Feature Challenged
Thanks fellas!
Does the search bar only search within the category you're presently in, or does it search the entire site?
For instance, if I executed a search while on this post within GENERAL DISCUSSION, will it only search GENERAL DISCUSSION?
27 Apr 2023 10:57 #4
I don't know what search you're using but it makes me wonder... the "search forum" here has a box for "keywords" and a box for "user name" (if you want to search for posts by a specific person) at the top.
Right below that there is a section that lets you narrow down the search to specific dates or specific areas of the forum. Default is all categories. You can also specify other things like sort order.
If you aren't seeing these options, you might be using the wrong "search"... see Gr8uncleal's post above.
27 Apr 2023 11:09 #5
"Thanks fellas!
For instance, if I executed a search while on this post within GENERAL DISCUSSION, will it only search GENERAL DISCUSSION?"
Pretty sure that it searches in all categories.
27 Apr 2023 11:31 #6
  • RT1
I've been using the search box that's at the top right of each page (just above the first posting on the page) within a particular thread subject... for instance would appear below "1967-71 Badge Bikes"
As Mark suggested, I tried using quotations and got a better result but I need to dig because given how long LED's have been around now and how many members there are I'd think that the subject has been covered and clearly spelled out by now. So far all I came up with was someone buying 1975 headlight trim ring and a Harley-Davidson lens.
I'm sure there's got to be a clearer and simpler path.
If at first you don't succeed, try, try, again
Last edit: 27 Apr 2023 12:38 by RT1.
27 Apr 2023 12:35 #7
Stock headlight runs on AC, LED needs DC so very few posts on the topic.
With VAPE headlight will be DC but you have a LOT of power so no need to use LED.
TONS of posts on replacing stock headlight with various 5 3/4" headlights. Just need clips, no need for a new ring.
If they make LED headlights in 5 3/4", then pick one of those instead of a common 12v sealed beam or common 12v H4 reflector/lens and bulb. Done.
27 Apr 2023 12:54 #8
  • RT1
Thank you Mark!
My search turned up this old discussion regarding H4 conversion, which will be sufficient for what I wish to accomplish... and that's to be seen.
www.yamaha-enduros.com/index.php/forums/...&childforums=1&ids=1
Very helpful suggestions and using the info I gathered there, I ordered the following which should do the trick....
From Amazon:
From MikesXS:
I chose the Amazon means of purchase for the lens because I find that my local auto parts stores to be basically useless unless you're prepared to provide - year, make, model, trim package, exterior color, interior color, and cup holder locations
All I should need now is a H4 hi/low Halogen Bulb.
Onwards!
The following user(s) Liked this Post: AirborneSilva, Sneezles61
Last edit: 28 Apr 2023 07:26 by RT1.
28 Apr 2023 07:23 #9
Replied by Sneezles61 on topic Site Feature Challenged
For what you’re doing, that works very well. The more very specific, related to cup hold locations, takes alot more looking and knowing a plastic bottom cup holder from a rubber one… I goof them up alot…
Sneezles61
28 Apr 2023 11:45 #10
