CT3 - 135 miles after rebore.
- Bdee
CT3 - 135 miles after rebore. was created by Bdee
I used yamaha piston and rings and had it bored out by Bill Bune Enterprises. I see some scoring. on the intake side of the cylinder. I can just barely feel the ridges passing a finger nail across them.
Is this a major issue?
18 Apr 2023 16:49
Replied by MarkT on topic CT3 - 135 miles after rebore.
Check air filter and boots.
The following user(s) Liked this Post: Enduronut, DaveR
18 Apr 2023 17:09
- Swoop56
Replied by Swoop56 on topic CT3 - 135 miles after rebore.
Cylinder wall looks quite dry . Perhaps check your oil pump is working , and output in spec too .
18 Apr 2023 17:53
Replied by RT325 on topic CT3 - 135 miles after rebore.
What was the reason you pulled the head. If it was running ok its best not to look--me thinks.
The following user(s) Liked this Post: Bdee
18 Apr 2023 19:04
- Bdee
Replied by Bdee on topic CT3 - 135 miles after rebore.
I wiped it down for the photo.
18 Apr 2023 20:36
- Bdee
I am hearing what I would call a howl. It's barely perceptible but I don't think I heard it before the new top end.
18 Apr 2023 20:38
- asco
Replied by asco on topic CT3 - 135 miles after rebore.
Full synthetic oil in the oil tank or premix?
a
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
18 Apr 2023 21:32
- msavitt
Replied by msavitt on topic CT3 - 135 miles after rebore.
did you wash the cylinder with detergent after boring and before assembling?
scores look like contamination got in (e.g. intake), or was in (some grit from boring)
howling could be intake noise?
19 Apr 2023 08:52
- Bdee
Yamalube 2s in the tank.
- Bdee
no I did not wash with detergent.
I wiped it down with a rag soaked in acetone and blew it out with compressed air. dam. I forgot the detergent.
19 Apr 2023 10:35
