Help Compressing piston rings help
  • type one
  • type one's Avatar Topic Author
  • Platinum Member
  • Platinum Member
Help Compressing piston rings help was created by type one
Hi
Any good tips or guides  for compressing rings and getting the barrel on without damaging my fingers or rings?
or do I just buy a ring compressor from tool mart?
thanks
T1
DT1's mainly -
1968 AUS
1969 B scabby track bike
1969 B MX project
73 CT3 project
BMW GSA 2018
13 Aug 2022 07:50 #1
  • type one
  • Platinum Member
  • Platinum Member
Replied by type one on topic Help Compressing piston rings help
It’s occurred to me cable ties would help … and they did … barrel back on !!
DT1's mainly -
1968 AUS
1969 B MX project
73 CT3 project
BMW GSA 2018
13 Aug 2022 08:33 #2
Replied by MarkT on topic Help Compressing piston rings help
Nice job and great idea!
I've never used a ring compressor on these bikes...  sometimes I wish I had an extra set of hands to hold cylinder up.
13 Aug 2022 10:10 #3
  • type one
  • Platinum Member
  • Platinum Member
I momentarily was goi g to ask my Mrs and then dimsolissed it …. Cable goes is the way forward !!
DT1's mainly -
1968 AUS
1969 B MX project
73 CT3 project
BMW GSA 2018
13 Aug 2022 10:14 #4
Replied by msavitt on topic Help Compressing piston rings help
I've fabricated nice compressor using a worm hose clamp of the correct size.  I cut the band off and bend two finger thingys....I have also used the clamp as-is and then removed it after..either way worked terrific for me.  Still helpful to have another person around to hold the cylinder!
13 Aug 2022 10:46 #5
Replied by RT325 on topic Help Compressing piston rings help
Depending on the motor you could lie the bike on its side so gravity is overcome then with it sitting on the studs like a DT3 250 or the like, then can controll it over the rings. Tis a fiddle i know, & worse if no decent lead in on the cylinder liner.
13 Aug 2022 20:28 #6
Replied by Pedalcrazy on topic Help Compressing piston rings help
Guess I didn't know better...old Yamaha shop manual just shows the mechanic compressing the rings with left hand and grabbing the cylinder with right hand and sliding it on. Done. I've used ring compressors assembling car engines but the 360 and 400 bikes go together as the shop manual shows.
The following user(s) Liked this Post: MarkT, LETSJET, Ht1kid
16 Aug 2022 17:19 #7
Replied by Ht1kid on topic Help Compressing piston rings help
+1 pedalcrazy
Last edit: 16 Aug 2022 17:22 by Ht1kid.
16 Aug 2022 17:21 #8
Replied by Sneezles61 on topic Help Compressing piston rings help
It is a completely different process when you can’t slide the piston into the cylinder, then bolt it to the crankshaft…
It’s like…. Learning a new trick if you haven’t played with these..
Sneezles61
16 Aug 2022 19:23 #9
  • type one
  • Platinum Member
  • Platinum Member
I did check  Dt1-e service manual and yes the process was clearly shown as you described and I gave it a go but tbh I didn’t want to damage the rings ….. I had to have a rebore to 4th over as it was siezed when I acquired the bike and the piston I have is keystone and not flat ring so I was probably being over careful as there aren’t that many around atm …..
good to hear other options etc so thanks for your input guys!
cheers
T1
DT1's mainly -
1968 AUS
1969 B MX project
73 CT3 project
BMW GSA 2018
16 Aug 2022 22:19 #10
