Uni 1409-st fail
  • Tom P
  • Tom P's Avatar Topic Author
  • Platinum Member
  • Platinum Member
Uni 1409-st fail was created by Tom P
I've had this Uni 1409-st  filter on my CT-1 for about a month, and after a long ride today, I just noticed it was hanging off the carburetor and the collar had torn. I noticed that it's very soft rubber, and actually the carburetor opening is a little bit small for this filter, so maybe when I tightened down it just was too much for it? JFYI
12 Aug 2022 13:31 #1
  • Schu
  • Schu's Avatar
Replied by Schu on topic Uni 1409-st fail
Hey Tom, maybe you can repair that with the proper type of glue, and then use Teflon tape to bring the carb inlet to a desired fit. Seems a shame to pitch a fairly new filter.
Last edit: 12 Aug 2022 13:40 by Schu.
12 Aug 2022 13:40 #2
  • Tom P
  • Platinum Member
  • Platinum Member
Replied by Tom P on topic Uni 1409-st fail
I think maybe it just couldn't take the heat. On the CT1 it's getting a lot of heat coming up from the crankcase, and where it failed was on the bottom of the collar. I sent a message to the seller to see if they could either replace a refund, if not I'll just write it off. I put my metal mesh pod back on, I only ride on the roads right now anyway.
12 Aug 2022 13:55 #3
Replied by Sneezles61 on topic Uni 1409-st fail
Is there a way to put some foam filter over the metal pod?
Sneezles61
12 Aug 2022 16:34 #4
  • Tom P
  • Platinum Member
  • Platinum Member
Actually that was something I was thinking of trying to do, put some foam around the metal one. I might try to salvage some from this unifilter and see if I can wrap it around there. It's outside of the return window so I'm eating it, oh well.
12 Aug 2022 17:05 #5
  • Tom P
  • Platinum Member
  • Platinum Member
This is interesting, I had it up to 65 the other day, and since I put the metal pod on now it's starting to cut out at 55 like it did when my main jet was dirty. I checked the main jet and it's clean as a whistle, I'd already cleaned it with an ultrasonic cleaner. I tried both spark plugs, and both of those are clean as well, and gapped correctly. I wonder if I'm getting too much air now when it's WOT?
12 Aug 2022 17:31 #6
  • Tom P
  • Platinum Member
  • Platinum Member
I did some experimenting and found the problem. First I cut a piece of inner tube, and put it over the mesh pod filter to cover about half of it, just to restrict the air. It ran worse. Then I rode without an air cleaner and it runs perfectly. No stumbles and I easily got over 60 mph. Then I realized something I hadn't really thought about, the opening on the pod filter is much smaller than the mouth of the carburetor. So even though I thought it was letting too much air in, at WOT it's like it has a restrictor on it. So I need to find another filter that does not have that small restriction.
12 Aug 2022 18:42 #7
I have a pod on my trail 90, and it doesn’t have that big hunk of rubber like yers…
No way to use a fillet knife and carve some of the restricted stuff out? U til you get it sorted out?
Sneezles61
12 Aug 2022 19:54 #8
  • Tom P
  • Platinum Member
  • Platinum Member
I thought about that, but the actual opening of the metal is restricted. When I first started working on this bike back in March, I  bought those inexpensive pods really quick because I didn't have any air cleaners. It never occurred to me that the restricted opening would cause a problem, but it does. I've already ordered another one that looks like it has a full opening that will arrive tomorrow. I want to ride to a vintage bike meet on Sunday :0)
Last edit: 12 Aug 2022 20:13 by Tom P.
12 Aug 2022 20:09 #9
  • Tom P
  • Platinum Member
  • Platinum Member
Got the new pod and it has a full size opening. Went for a ride and it runs great. I'm just going to roll with this for now, I'm only riding around town, not off-road, and it's not a rural area where I could run into dust storms That's said, I'll keep an eye out, maybe there's some kind of foam sock you can put over these things?
13 Aug 2022 13:15 #10
