Husky 250 CR
- yamahahaha
Husky 250 CR was created by yamahahaha
My new to me Husky 250 CR. Had to show
05 Aug 2022 16:10
- Schu
Replied by Schu on topic Husky 250 CR
That's BadAss!
Love those forward mounted shocks.
05 Aug 2022 16:13
- yamahahaha
Replied by yamahahaha on topic Husky 250 CR
Hey Mark T ! You have a 1976 don't you ????
05 Aug 2022 16:14
- yamahahaha
Thanks Schu
05 Aug 2022 16:15
- AirborneSilva
Replied by AirborneSilva on topic Husky 250 CR
Nice bike John, enjoy your new toy
05 Aug 2022 16:22
Replied by MarkT on topic Husky 250 CR
I have two of them... yours has the "snake pipe" which means it's a higher VIN for 76 or someone installed the 76-1/2 pipe.
The black air filter cover was a 77 model feature... other than than yours looks like a 76. That tiny muffler is very rare so don't toss it.
Rear fender is probably broken because it's a very quick, light bike... easy to loop over backwards if you grab a handful of throttle and the rear tire grabs traction, even at higher speeds.
05 Aug 2022 16:35
- yamahahaha
Ya back fender . Got it that way broke. I know VERY little about Huskies but it appears original. Maybe you can tell me .The bike tire has the word Barum. Is that an original tire ???
05 Aug 2022 16:50
- yamahahaha
Hey Mark frame is ML 10352 Engine is 2042 2887
05 Aug 2022 16:52
Yours is a 1976... the 76-1/2 models I personally know came with that pipe originally were above frame number 11500. But I have no idea when the change was made... with your frame in the 10,000 range it easily could have come with that pipe. Mid-year 1976 250CR was the first Husky to come from factory without the classic Husky side pipe. New pipe was reportedly designed by a young Husky engineer by the name of Ohlins... who went on to design shocks.
If you need cables you might find the ones people sell are not quite right... but you can modify new ones sold to fit. It was a transition bike with some of the new ideas (like front wheel with brake on left) that made it to the 77 models. Air filter cover is not original which is strange because it looks like rest of bike is.
Be careful with kick starter. Crap design. it hits shifter as a "stop" at bottom of travel which beats the hell out of shift shaft bushing in case and can break case. 1978 kick start lever is much better but hard to find.
DO NOT remove kick shaft from splines without marking and researching! It is a pain to install and time correctly. If you don't install it right you will blow the case cover to hell. Cover can be removed with kick start and shifter left in place. They come off with cover.
05 Aug 2022 17:19
Forgot to mention that Barum was original tire brand on my 1976's.
05 Aug 2022 17:43
