Ultrasonic Cleaner Questions
- Tom P
Replied by Tom P on topic Ultrasonic Cleaner Questions
Been cleaning the carburetor up again, and I just realized I don't know what is in that opening below the orange mark. That's where a tube from the upper section goes into, and it doesn't look like it's a jet, it doesn't have a slot for a screwdriver. Looking on the Partzilla diagram, it doesn't mention anything about it.
26 Jul 2022 12:34
#11
Replied by Gr8uncleal on topic Ultrasonic Cleaner Questions
There will be a small fixed brass jet in the bottom (well, there should be!) and this is for the choke/cold start. Squirt some carb cleaner or the like down there, just to make sure that it isn't blocked.
For the Yamaha twins, only the left hand carb (with the choke lever) has this opening - on the other side it is blanked off. Poor starting can sometimes be down to the float bowls being inadvertently swapped over.
26 Jul 2022 12:44
#12
- Tom P
Excellent, I appreciate the information! I did make sure that it's clear, then I blew it out with compressed air. It does look like there's a jet down there, it just doesn't have a slot for removal .I'll go ahead and put it back together and see what happens.
- Schu
Replied by Schu on topic Ultrasonic Cleaner Questions
Hey Tom your last sentence would make an awesome T-shirt.
Put it back together and see what happens!
The following user(s) Liked this Post: AirborneSilva, Tom P, TuningFork4ever
26 Jul 2022 14:09
#14
- Tom P
I'll have to print those up and start selling them here :0)
It's running great, though it was running well before. Carburetor is a lot cleaner though, and it was idling about 150-200 RPM more, even though I didn't change any settings. I turned it back down to about 1200. I think the pilot jet is cleaner than it was.
26 Jul 2022 14:25
#15
- Superdad60
Replied by Superdad60 on topic Ultrasonic Cleaner Questions
Never use that purple power on aluminum
My old corvette parts can attest to that
27 Jul 2022 08:19
#16
- Tom P
Another question on the carburetor. The air adjustment screw seems to be connected to the larger hole in the center of the bottom of the mouth of the carburetor. The small open hole on the right doesn't seem to go anywhere. Is that correct?
27 Jul 2022 09:56
#17
- TuningFork4ever
Replied by TuningFork4ever on topic Ultrasonic Cleaner Questions
New to the site today, I've used Simple Green with good results
28 Jul 2022 17:34
#18
- asco
Replied by asco on topic Ultrasonic Cleaner Questions
Most cleaning items for Ultrasonic Units can be purchased at the .99 cent store. You do not need to spend $7.99 on something you’ll use one time.
a
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
28 Jul 2022 17:55
#19
