High idle on enduro dt 175
- Endurobeginner
Replied by Endurobeginner on topic High idle on enduro dt 175
Thanks for the advise I wish I new about the leak test before I removed the Reed valve and rubber intake and put new gasket gum and new gasket. And thanks for reminding. Me how do yo identify a original mikuni carb .
15 Jul 2022 20:01
#11
Replied by Ht1kid on topic High idle on enduro dt 175
Amen MarkT you nailed it again. Post some pictures of your carb also any numbers on your carb
15 Jul 2022 21:55
#12
- Endurobeginner
Can anybody tell me what the model of the carb for a enduro dt 175 vm24 or vm28 ?
16 Jul 2022 04:52
#13
Replied by MarkT on topic High idle on enduro dt 175
VM 24... but that doesn't mean a whole lot as there are many, many variations.
If original carb should have tiny numbers stamped on choke boss or side of carb. (your carb would have a "pull knob" choke)
16 Jul 2022 05:50
#14
Also, there is no reason you can't pressure (and then vacuum) test the engine... Many posts on here about it and how to do it. Not that hard or expensive and then you know it's sealed up. Huge time, money, and engine saver in my experience... first thing I do on a new to me two stroke if having issues.
Most people would rather "guess" or just replace parts and hope for the best it seems. That's okay too.
There should be an article in Tech Library on the process if you don't want to search.
16 Jul 2022 05:57
#15
16 Jul 2022 06:01
#16
Replied by RT325 on topic High idle on enduro dt 175
Did you look through the carb. Shouldn't see light under the closed slide.
16 Jul 2022 16:17
#17
- Endurobeginner
Yes the carb slide is fully closed.And as shown on the picture it has a number on the side of the carb.But my carb has a inner diameter of 28mm in the engine side is that correct.
16 Jul 2022 20:42
#18
Regardless of if it's the right size or not it should still shut off. I thought Mark put those carb pics up here, its just that one was set to about idle slide height. But i guess was just pointing out numbers on the carbs. Don't worry, just me not reading right. I've got a 28 on my old 175, Chinese 28, which was not fully machined so only about 25 or so. Works good all the same.
16 Jul 2022 21:03
#19
I must have missed it if you posted picture of your carb.
28 can work. Original was closer to 24... but size is measured down by slide so outlet ID sometimes measures a little bigger... like a VM24 might measure 25 or 26 ID at spigot.
16 Jul 2022 21:24
#20
