plug chop without a kill switch?
- Bdee
plug chop without a kill switch? was created by Bdee
Is it possible? Is it feasible?
29 May 2022 21:03
- DT400FRANK
Replied by DT400FRANK on topic plug chop without a kill switch?
Not really. Unless you can unscrew the plug real fast while your riding.
The following user(s) Liked this Post: Bdee
30 May 2022 00:04
Replied by RT325 on topic plug chop without a kill switch?
I've never actually done one, but could you screw out the throttle stop so slide hits the bottom & grab the clutch & coast to a stop & motor would be long stopped. Or are you meant to kill the spark but hold it on full song [which would wet the plug till it stopped revolving. CT3 just tie a string around the plug lead & around your leg & kick out at speed to kill the spark. Sorry i'm having vision of that, so maybe not a good plan.
30 May 2022 01:25
- DT400FRANK
You should really have a kill switch. How do you cut off the bike now?
30 May 2022 01:43
- Bdee
Replied by Bdee on topic plug chop without a kill switch?
The key in the ignition switch,
30 May 2022 07:34
- Pete-RT1
Replied by Pete-RT1 on topic plug chop without a kill switch?
If you have an ignition and key why do you need a kill switch?
Yamaha CT3 (in bits)
30 May 2022 12:40
- JayB
Replied by JayB on topic plug chop without a kill switch?
I agree with RT325, set up a dead man throttle: "could you screw out the throttle stop so slide hits the bottom & grab the clutch & coast to a stop & motor would be long stopped."
DT400 FRANK wrote: "You should really have a kill switch. How do you cut off the bike now?
Here: yamaha-enduros.com/index.php/ownders-man...er-s-manual/download
it says:
Haha, put it in gear and dump the clutch with the back brake on! Obviously no help when doing a plug chop.
My first Bultaco was like that, a dirt bike with no main switch or kill switch. I added a kill switch pretty quickly!
it says:
