Sprocket set up
  • Gibz
  • Gibz's Avatar Topic Author
Sprocket set up was created by Gibz
Greetings
I would like to make my DT2 a bit more road worthy on the top end. Currently has a 47T in rear with a 14T in front. Really not sure how to gear this up properly to cruise at 55 max without 1st being too tall. As is, its screaming more then I would like at 50. Any suggestions on a proper set up. As I recall it takes a 520 chain size ?? Thank You!
07 May 2022 20:14 #1
Replied by Swoop56 on topic Sprocket set up
Your 14T front is stock size for a DT2 , but your rear is 3T larger than 44T stocker .
Try a 15 T front , as you'll quite likely get away with your current chain .
That will put you pretty close to stock gearing .
If that doesn't cut it , you might have to get a smaller rear .
The following user(s) Liked this Post: Gibz
07 May 2022 22:59 #2
