Vape System Feedback and Purchase advise
  • Quartermaster35
  • Quartermaster35's Avatar Topic Author
Vape System Feedback and Purchase advise was created by Quartermaster35
I am really interested in some feedback from those of you that have purchased the system?
Is it worth it?
Where did most of you purchase it from in the US?
1973 Yamaha CT3 175
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1980 Yamaha 175 Tri-Moto
1969 Yamaha DT1 250
1981 Yamaha XS650 Special
1982 Suzuki GS550ES
1982 Honda 250R
1984 Honda Nighthawk "S"
2005 Kawasaki KLR650
27 Mar 2022 05:31 #1
Replied by MarkT on topic Vape System Feedback and Purchase advise
Possibly no responses because it's been discussed here many times.  Summary:
Great system
No flywheel key, (key is mostly "assembly aid", not required) HVC Cycle might add keyway if you must have.
If you don't have a clue on how to time or know someone that does you probably shouldn't screw with ignition if you don't want to learn
Best deal by far is to buy direct from VAPE.
And again, lots of info if you search forum for Powerdynamo or VAPE.
28 Mar 2022 17:47 #2
Replied by RT325 on topic Vape System Feedback and Purchase advise
& as always--if no crank key then do it up super tight to avoid it slipping & i hope your crank taper is good, which it will be if its not broken the crank key previously. 250-360 motors suffer more from that problem.
28 Mar 2022 19:07 #3
Replied by Bigdog302 on topic Vape System Feedback and Purchase advise
If the taper is in rough shape, you can restore the taper by taking the valve lapping compound and putting a small amount on the crank, find a way to lock the engine by putting some long rope through the spark plug hole then work the flywheel back and forth. once you get a gray area all the way around the crankshaft and the flywheel you plan to use.
make sure you clean the crank and flywheel when you are done
Dave
Jesus is Lord!
Last edit: 28 Mar 2022 23:23 by Bigdog302.
28 Mar 2022 20:19 #4
  • Quartermaster35
Replied by Quartermaster35 on topic Vape System Feedback and Purchase advise
Thank you for the responses.
1973 Yamaha CT3 175
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1969 Yamaha DT1 250
1982 Suzuki GS550ES
1982 Honda 250R
29 Mar 2022 04:50 #5
Replied by mx360guy on topic Vape System Feedback and Purchase advise
I have good experiences with the VAPE systems. I have successfully used on a 1975 DT250 motor and now have it on a '73 MX360 engine.
I also have one on a `1978 Suzuki SP370. I can't believe they make them for those beasts. Works great. Can run LED lights and turn signals.
Make sure your carburetor is working good so you don't  chase an ignition problem that is really a fuel issue.
I had that issue with the SP. I took the carb completely apart and had a very hard time getting the air screw/pilot screw adjustment back to a place where it runs good at all throttle positions. The manual says NEVER touch these and now I know why. It ran like @#$% until I got it set back.
29 Mar 2022 09:52 #6
