1975 DT250 trans oil dipstick
- chadfitz
1975 DT250 trans oil dipstick was created by chadfitz
Im changing my oil getting ready for spring. Found the thread talking about the fact that it may take overnight to settle and read correct on the dipstick. Im hoping it does and will check in the morning. Because after I filled it with 1 liter, it reads about 2" up. While I wait the question I have is, the dipstick is about 5-6" long with only about 1/4" with crosshatches. Is this correct? Hi to low mark is within that 1/4"? I just want to make sure I have the right dipstick. ..
75 dt250
73 ct175
73 ct175
11 Mar 2022 17:23
- Schu
Replied by Schu on topic 1975 DT250 trans oil dipstick
That sounds correct, but I will go out to my barn tomorrow and pull my dipstick and measure it for you.
Stay Tuned
Stay Tuned
11 Mar 2022 17:31
- chadfitz
- Schu
Both of my DT250Bs have the same dipstick as you described.
And yes, the proper level is that cross hatched zone at the very end.
You do not thread it in for checking the level.
You insert it until it contacts the threaded portion, with the bike upright and not leaning on the kickstand.
The following user(s) Liked this Post: MarkT, Bigdog302
- chadfitz
Replied by chadfitz on topic 1975 DT250 trans oil dipstick
OK thanks.
Update: came out this morning and it is still 1 34" up the dipstick, so about 1 1/4" to "full/high".
So...
Did i not let it drain long enough?
Can I run it to warm it up with it this high? In order to completely redrain it?
Or should i just use a syringe to remove the extra?
Curious just because i didnt think i could screw up draining and refilling the oil!!!!! Go figure.
thanks
So...
thanks
75 dt250
73 ct175
73 ct175
12 Mar 2022 08:01
- Schu
Syringe idea sounds good if you got one that will dip into the oil. Less hassle than a partial drain. I don’t know the results of starting it when overfilled.
12 Mar 2022 14:42
- chadfitz
UPDATE: I didnt have a syringe, so I put the bike on a stand, rear tire off ground.
set the dipstick in the whole but did not thread it in(figuring this would not allow any pressure to build up.). started the bike, put it in gear and let it run like that for maybe a minute. shut it off, put bike down, checked oil, and it was perfect.
So i guess it took putting it in gear to let the oil go to wherever it needed to go.
thanks for the help
thanks for the help
75 dt250
73 ct175
73 ct175
12 Mar 2022 16:09
- Schu
You might want to check it again after it sits for a while. If you checked it as soon as you shut it off like you described, then you didn't get a proper oil level.
WRONG!
See below.
WRONG!
See below.
Replied by MarkT on topic 1975 DT250 trans oil dipstick
You might have checked the level "by the book"? Instructions say to warm up bike for several minutes before checking. Nowhere does it say to let the bike sit a while before checking?
12 Mar 2022 19:31
- Schu
Ha……
I’ve been doing it wrong since the beginning!
I always thought you had to let the oil settle back into the sump, so to speak.
I really shouldn’t answer questions……
12 Mar 2022 19:37
