Fuel Filter : Are most of you using one?
- Quartermaster35
Fuel Filter : Are most of you using one? was created by Quartermaster35
I don't believe that most of the Yamaha's originally came with one..... Just curious if most have one installed or not?
I put one on my CT3, but it sure is a tight fit to get it all in there (seems like a "good idea")
1973 Yamaha CT3 175
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1980 Yamaha 175 Tri-Moto
1969 Yamaha DT1 250
1981 Yamaha XS650 Special
1982 Suzuki GS550ES
1982 Honda 250R
1984 Honda Nighthawk "S"
2005 Kawasaki KLR650
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1969 Yamaha DT1 250
1982 Suzuki GS550ES
1982 Honda 250R
06 Feb 2022 11:14
Replied by Gr8uncleal on topic Fuel Filter : Are most of you using one?
You do see them fitted on a lot of bikes nowadays. I've read, though, that a constant fuel supply to each cylinder can be an issue if fitted to twins.
As well as any filters in the petcock, the reserve pipe in the tank is filtered. Whilst the main pipe isn't, it is possible to fit one over the top of it.
Some folks fit in line filters for the oil feed - there is a brass filter in the oil tank, but the "mesh" might be quite coarse.
06 Feb 2022 11:36
- Pedalcrazy
Replied by Pedalcrazy on topic Fuel Filter : Are most of you using one?
I make sure my petcocks have the original filters and my tanks are clean. I never liked the looks of aftermarket filters.
06 Feb 2022 11:58
- adguy2112
Replied by adguy2112 on topic Fuel Filter : Are most of you using one?
Looks or not I put in line filters on all my bikes. I get seriously tired of removing carbs. Even with a good petcock filter the in line filter still manages to catch particles.
06 Feb 2022 17:33
- asco
Replied by asco on topic Fuel Filter : Are most of you using one?
Always.
a
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
- darinm
Replied by darinm on topic Fuel Filter : Are most of you using one?
I do too, if the gas tank is not pristine. Had cleaned my CT2 tank with a vinegar soak but it had a lot of surface rust. Eventually plugged a filter, and have plugged the pilot twice even with a filter installed. Hopefully she is past that now!
1972 Yamaha CT2 175
1972 Suzuki TS185 Sierra
1997 BMW R1100R
2013 Yamaha XT250
1997 BMW R1100R
2013 Yamaha XT250
06 Feb 2022 20:41
- Quartermaster35
Replied by Quartermaster35 on topic Fuel Filter : Are most of you using one?
Thanks for the responses....
1973 Yamaha CT3 175
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1969 Yamaha DT1 250
1982 Suzuki GS550ES
1982 Honda 250R
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1969 Yamaha DT1 250
1982 Suzuki GS550ES
1982 Honda 250R
07 Feb 2022 06:32
- msavitt
Replied by msavitt on topic Fuel Filter : Are most of you using one?
all of my 44 to 52 year old tanks ranged from dirty to absolutely filthy, so after cleaning them as good as possible I removed the tiny filters that are internal to the petcock and replaced with see-through external filters so I could catch all the crud and not have petcock filters clog up on middle of the road. After first or second external filter change the filter runs nice and clean and I decided to keep these larger external filters than to reinstall the very easy to clog internal petcock filters.
The following user(s) Liked this Post: Schu, adguy2112
07 Feb 2022 09:42
