To CHROME or not to chrome, that is the question....
- DT175DOUG
To CHROME or not to chrome, that is the question.... was created by DT175DOUG
So when my 74' Suzuki TS185 gas tank got attacked by Santa in the moving trailer, I was told that original tank was trashed and couldn't be fixed by two different repair shops. So I bought another tank on Ebay that had surface rust and was useable. That tank is being restored right now. It came with this original locking gas cap which needs to be rechromed.
I don't know squat about the chroming process.
QUESTION: Can this cap be rechromed as-is or would it have to be taken apart, and is that even possible?
BTW- I found a place in Ohio that IS restoring my original gas tank. He said he would rather take out a dent than work on a rusty tank.
So I will have two restored tanks now.
27 Dec 2021 15:29
- JGersh
Replied by JGersh on topic To CHROME or not to chrome, that is the question....
Did anyone suggest sending the dented tank to a paintless dent removal person ? There are several who specialize in motorcycle tanks and can work miracles. I speak from experience.
2 - ‘68 DT1
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
‘12 Triumph Scrambler
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
27 Dec 2021 15:53
- DaveHunter
Replied by DaveHunter on topic To CHROME or not to chrome, that is the question....
Hi Doug,
The rubber seal is shot so you need to remove that and get a replacement, otherwise it will likely leak gas on the new paint job.
As far as chrome plating goes my experience has been leave the metal parts assembled on something like this, their processes have little effect on the mechanical parts underneath & actually leaves them with a dull protective finish.
Chrome plateing shop should be able to advice you based on above pictures
The following user(s) Liked this Post: DT175DOUG
27 Dec 2021 16:16
- Hardworker
Replied by Hardworker on topic To CHROME or not to chrome, that is the question....
You'll need to disassemble the cap down to only the piece you want plated.
27 Dec 2021 16:36
Replied by Ht1kid on topic To CHROME or not to chrome, that is the question....
Hey Doug I would see if you could buy a new one chrome plating has gone crazy expensive due to the epa regulations. They probably would like to have the lock and rubber removed
27 Dec 2021 16:44
- DT175DOUG
Replied by DT175DOUG on topic To CHROME or not to chrome, that is the question....
I think it was beyond a dent removal place? Here's a picture.
27 Dec 2021 16:59
- DT175DOUG
Thank you Dave. I will hunt a new seal down. Hopefully someone sells one. I don't see the part # in the parts manual, but I'm sure there is one to be found.
27 Dec 2021 17:44
- DT175DOUG
Thanks for the suggestion. I will shoot some photos to the chrome shop. We have an excellent one about 90 mintutes away in Johnson City, Tenn.
27 Dec 2021 17:46
- DT175DOUG
I will take a better look at the cap tomorrow. That would be great if its doable.
27 Dec 2021 17:48
Hey Doug I’m from Tennessee the other side of the state
27 Dec 2021 20:48
