Points
  • principal282
  • principal282's Avatar Topic Author
Points was created by principal282
I have a newly minted stator out of thr deet time machine.  I have installed it with the new yamaha woodruff key.  My points do not seem to open and close. I have a beep box setup and can manually do it but no rotation of the flywheel does it
ideas ?
My jug is back on miracle of miracles....
See picI have a newly minted stator out of thr deet time machine.  I have installed it with the new yamaha woodruff key.  My points do not seem to open and close. I have a beep box setup and can manually do it but no rotation of the flywheel does it
ideas ?
See pic
04 Oct 2021 15:45 #1
Replied by DEET on topic Points
Are you saying that your flywheel won't open the points?
Are you looking at them to see if they open or are you just using this beeper thing to tell you?
Keep in mind that the stator assembly made spark and all voltages before it left here. So that proves that it should open the points.
04 Oct 2021 15:59 #2
Replied by MarkT on topic Points
Need more clarification of your "beep box" and exactly what you mean.
If you're using a continuity tester, it will beep constantly.
04 Oct 2021 16:40 #3
Replied by RT325 on topic Points
If you loosen the points screw & let them rest on the cam & tighten it in the position the flywheel is now then they should open from about that point, just looking at where the flywheel is. Make sure that flywheel nut is tight or the crank key will suffer.
04 Oct 2021 16:53 #4
  • principal282
Replied by principal282 on topic Points
A beep box is similar to the aircraft magneto timing indicator. One lead to black,  the other to ground.
I got it!! It just took some learning for how to make that fine adjustment. I got the beep to hit right at 126 thousands (3.2mm) btc.
The stator is a beauty. A work of art
04 Oct 2021 16:53 #5
  • principal282
04 Oct 2021 16:54 #6
Great job!  Congrats!
(and DEET sure does make things look pretty)
04 Oct 2021 17:03 #7
  • principal282
got this from Dennis kirk after some searching.
04 Oct 2021 17:06 #8
  • principal282
Thanks Mark.
I use my current learning to help my school kids understand they should never quit learning and never be afraid to ask for help. Collaboration is how we all get smarter!!
04 Oct 2021 17:27 #9
